Question about LG LSC121PMA Split System Air Conditioner
I want to have one a/c unit in the hall 15x36feet and also another in a room 10x12feet.can you depute one excutive to study the place and to sujjest how to install .
  • 22 Answers
Need to see blue prints, also square footage will play a big role as to size you need in each area, and where you want to place them so copper an drain lines will be able to run, and where you want outsid units.
Posted on Feb 01, 2010
Serial # HLL 12,only numbers on gun, how old and base price
Hi Larry.
I found a listing in a State of Michigan gun data code manual
https://www.michigan.gov/documents/msp/NCIC_Gun_codes_as_of_8-5-2012_407670_7.pdf that links the HLL, in several places, to 'J. H. Hall/Hall-North' as Civil War Rifles. There are some listings here
https://books.google.com/books?id=WiK6kmJ6XukC&pg=PA151&lpg=PA151&dq=J.+H.+Hall/Hall-North+Model+12&source=bl&ots=61JUjZkJO0&sig=g1e_F-jZZlWHnLYkrnVb6cvdsAM&hl=en&sa=X&ved=0ahUKEwia6tD20s_JAhXLE5QKHfWEAX8Q6AEIOTAE#v=onepage&q=J.%20H.%20Hall%2FHall-North%20Model%2012&f=false of some Hall / Hall-North pieces listing at thousands or even tens of thousands of dollars, though I didn't find a HLL 12 mark specifically. The only mention of 12 there is as part of weights.
This
http://www.cornellpubs.com/free-files/United%20States%20Cartridge%20Revolver%20Names%201865-1930%20BW%20Portrait.pdf
mentions other brands (Tiger and Enterprise), made by Ely & Ray, and Enterprise Gun Works, respectively).
This mentions a B12 breechloading flintlock made by Hall in 1834
B12 Rifles 2 flintlock breech loading Hall Harpers Ferry Arsenal Virginia...
Sans description of form factor, firing mechanism, and the like, that's about as far as I can get at present. I hope this gives you some leads to identify and price the piece.
Happy Holidays
D
Dec 09, 2015 | Optics
My kyocera km-2550 multifunctional copier has started showing a error message "call for service c6000" and a phone number in asterisks. kindly advice on what to do or if there any online help.
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.
In order to reset this code: follow those steps
on the panel press 1087 1087
The screen will change to service mode
on the panel again press 163
now look at the screen and you will see Excute.
Select Excute and press the Start key.
The Machine will rebot or it will asks you to turn it off and on.
After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit.
Oct 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Placed in bedroom to heat large hall, office,dinning room, bathroom...making bedroom to hot
Placement of the heater is the problem. It needs to be in a more central location. Perhaps the hallway. That way, it heat has a more open area to travel and reach the areas you're trying to heat. Keep in mind though, it will always be hotter where the heater is located.
Be safe. Electric Space Heaters can start fires.
Mar 03, 2011 | Heating & Cooling
I am stuck in the powder room. I have a blue key but need a red key to go forward.
If you are referring to "Princess Isabella A Witch's Curse"
"After you get the blue key you have to go back to the hall by the dining room and unlock the study..then you will find the red key after you solve everything in the study, it's in the globe."
Copied from:
http://www.iwin.com/forums/posts/list/15/1643.page
Mar 02, 2011 | Video Game Consoles & Games
Connect my 24 milivolt gas (between the studs) wall furnace ( in my hall) to my thermostat that operates my electric heat central unit. problem: to sync both units to give home more balance ( hall is...
the first problem is you need a milli-volt t-stat and your central has a 24volt t-stat if you connect the 2 it will fry the controlls in the wall heater the second problem is t-stat location if the wall heater is near the central heats t-stat it will shut off the central to soon . maybe relocate wall unit to coldest room ?
Nov 16, 2010 | Honeywell Heating & Cooling
We have an air make up unit on our community hall with no heat
Depending on the outdoor temps, 10 kw won't heat much. If you have a multi-meter you can check the amp draw as well. You should get 20 amps for each heat strip. Each heat strip is 5kw.
Mar 23, 2010 | GE Built-In Room Air Heat Cool Air...
How long will my AC work for, if placed inside the room
I assume that we are talking about a "window" unit. No, you cannot just place it in the room. The machine is actually two parts; one part delivers the cool air to you, the other part ejects the heat out of your house. If you just had the whole unit inside, the room wuold actually get warmer, not cooler. The reason for this is that the compressor and motor generate heat also. The "heat of compression" generated has to be ejected from the room in order for the air conditioner to work. Put it in the window.
Best regards, --W/D--
Aug 10, 2009 | Heating & Cooling
Dont know how to turn on webcam on my compaq presario a900notebook
You need software to use it, something like deput, google deput webcam recorder or by using a messanging service with webcam chat on it, vague questing add detail if this doesnt help. :)
May 11, 2009 | Computers & Internet
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
