Question about HP 1040 Plain Paper Inkjet Fax
My hp 1040 fax will not send a fax or copy a document. It tells me that there are jammed papers when that is not true.
  • 3 more comments
  • Anonymous Mar 18, 2008
    I have a small piece of paper jammed and dont know how to get to it to remove it.
  • candi1 Mar 27, 2008
    My fax says it has a paper jam but it does not.
  • Anonymous May 07, 2008
    Fax says remove jammed paper and there is no jammed paper. message will not go away.
  • Anonymous May 14, 2008
    it is printing and copying blank papers
  • Anonymous Jun 11, 2008
    This is the second HO 1040 I have bought in the pass year and I get the same error and it can not be fixed. It says there is a paperjam and it is not.
  • 106 Answers
Check the paper tray,maybe some of the sensor stuck or dirty,just try to clean paper tray with compressed air.
Posted on Feb 18, 2008
Fax machine not copying?
If you have an HP 1040 or 1050 fax machine be sure tot checkout this article about the recall HP did on this machine due to a potential fire hazard. You need to contact HP before you have problems with the unit.
http://www.ccl-la.com/blog/index.php/recall-on-hp-1040-and-1050-fax-machines/
BuddyMc
Mar 01, 2012 | HP 1040 Plain Paper Inkjet Fax
Want to use HP 1040Fax machine to make copies
1. Turn the page face down and insert it into the document feeder.
2. Press Copy twice.
2. Press Copy.
Number of Copies then 01 [01-50] will display.
3. If you want more than one copy, use the phone pad to enter the number of copies.
4. Press Copy to start copying or press Start/Enter to go to the next option.
Zoom Rate then 97% will display.
Dec 05, 2011 | HP 1040 Plain Paper Inkjet Fax
What does the message "ecm" mean when trying to
Error correction mode error
Take a look at this article on the HP website: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01747846&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You may find similar instructions for your fax on that site as well.
Jan 14, 2011 | HP 1040 Plain Paper Inkjet Fax
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
When we send a fax with our HP 1040 Fax Machine, the people receiving our ads for newspapers, say it is too dark to read. Help!!
Lift the cover of the sheet feeder, and clean the filter glass that the documents are scanned across. If you make a copy on the machine this will give you an indication of the quality you are sending, so perhaps make a copy first, clean glass then try again. If the quality is still bad, then you have a deeper problem, such as the LED array (lights that light up during scan) is dying, or the optics within the machine are dirty -this would require the removal of the top of the machine to access and clean -not worth the trouble.
Hope this helps.
please rate my solution :)
Apr 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Says there is a paper jam but there is not
First, you have to clear the error first before sending the fax.
-open the rear access door at the back and check if there is any debris of paper. If none, close the access door and make sure you hear the snap and properly closed.
-lift the document feeder cover to check for any debris, and then close it properly.
-if error is cleared, try faxing again
Feb 26, 2009 | HP 1040 Plain Paper Inkjet Fax
When making a copy we get an ink stripe down the center
open up the document feeder and clean the scanner glass.
Jan 21, 2009 | HP 1040 Plain Paper Inkjet Fax
Send error
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00547&cc=us&lc=en&dlc=en&product=425911&dlc=en&lang=en
Dec 08, 2007 | HP 1040 Plain Paper Inkjet Fax
Jammed document
JC
I had the same problem- jam error with no paper in it. I tried all of the suggestions to no avail. So as a last resort before I went and purchased another one I unplugged it, picked it up, turned it upside down and whacked it a few times. To my surprise when I plugged it back up it worked just fine! Haven"t had any problem since. I don"t reccomend this but as a last resort, what the heck!
Jan 30, 2007 | HP 1040 Plain Paper Inkjet Fax
HP 1040 Plain Paper Inkjet Fax Logo
131 people viewed this question
Ben Johnson
