Question about Maytag Washing Machines
Maytag Neptune Washer model # MAH9700AWW will no longer despense fabric softner,
  • 2 more comments
  • yogimd96 Jan 30, 2010
    egraber,
    Yes I have both hot & cold water. Not sure what you mean by syphone cap? Is that the blue cap that has "Bleach" on the front, & "softner" on the back?
  • yogimd96 Feb 02, 2010
    When water will syphon down.
    Sorry about, when water is goes above the max line it will syphon down.
  • erica graber May 11, 2010
    have you cleaned the syphone cap is there water in it have you checked to see if you have both hot and cold?
  • 530 Answers
Yes the cup that the fabric softner goes into the cap of it is called the syphon. poor water in the cup and go over the max line does it syphon the water?
Posted on Jan 31, 2010
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What does the code suds mean on my maytag neptune washer
sud's ( like to much soap ) this causes the machine to shut down . mix some downey of fabric softner in a quart of water . pour it in tank . let set over night . and try again . fabric softner will get rid of suds or at least reduce them . it will probably work .. mm
Dec 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune washer is dispensing fabric softner during wash cycle! help!
not good. the board usually tells the dispenser to activate and send water to you fabric softner, ive seen two different problems on the maytags, your water valve could be bad or clogged or the board is bad.
Sep 17, 2009 | Maytag Washing Machines
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
Feb 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
My neptune washer will not drain the fabric softner container
This is joyce
I have advice for you check the siphon cap to see if its twisted reposition cap.
thanks
joyce
Jan 17, 2009 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
183 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
