Question about Intel Biostar P4TSE-D2 865 Chipset Mainboard for Pentium 4 533/800 FSB w/ 8X AGP and Serial ATA (MBSK478BIOP4TSED) Motherboard
I have two frontpanel usb port... show me the connections [usb to motherboard] my system is P4 configuration...
Iwant to connect my speaker
Posted on Jan 30, 2010
Front USB wiring configuration on an Elite 661FX-M Rev 1.0 motherboard
This is the usual configuration of USB connection on motherboard.
If you have single cables (4 separate cables for each USB port), connect following wires in order to the right side pins from top to bottom.
+5V (1) P4 - (1) - You may have any number in place of 4 P4 + (1) - You may have any number in place of 4 GND (1)
On left side, connect
+5V (2) P5 - (2) - You may have any number in place of 5 P5 + (2) - You may have any number in place of 5 GND (2)
Jul 22, 2011 | Computers & Internet
Hello! my problem is that my two USB ports is blown. Now I want to connect more USB port on the motherboard via cable, but none matches the port that the USB or sb_link, jp1... Can you tell me which port...
You will need to get a usb expansion card. These can be found at Best Buy, Newegg.com, tigerdirect.com, pc-connection.com etc...
Some manufactures ship with newer motherboards a usb expansion slot using the motherboard jumper configuration but your motherboard must first be able to support this type of expansion.
I recommend the pci usb expansion. They plug into your PCI slot and give you 2-4 extra USB slots in the back of your computer.
Mar 01, 2011 | Quadrant Slot 1 QM-6VABX2 (QM-6VABX2-1664)...
I require instruction on the use of my portable hard drive.
its very easy. just connect to your computer usb port. If your drive requires power put the power adapter. Before connect to frontpanel USB of your system. Once check your front panel usb is working or not. Check with some other memory stick or mouse etc.. Because if your front panel usb connect reverse there is chance to lose your hard drive..
Jun 24, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
My computer is not working shows keyboard erro and stop
Hi...
When you monitor saying which is no signal this is a monitor port problem. Check your monitor connector if it is properly connceted to the motherboard. That is the only way of monitor saying no signal.
Regards
PCmania
Aug 22, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My gigabyte 8S661FXMP-RZ system running server2003 sp2 no longer recognizes my coolmaster x-craft external usb drives, please help
Some times it happen due to improper removel of usb drives or malfunctionning with the ports on the board. first remove the usb drive >chk system tools>sub devices & ports the drivers are proper or not then rollover the drivers the problem is not solved re install the drivers. still have a problem get back to me
Jul 09, 2009 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
P4 Titan GA-8ST800 Motherboard USB Power Failure
You can also install a PCI USB add-on card in your machine, that will give you more usb port, it happens a lot that the usb's fail on a motherboard, there is no fuse to reset them...soryy
Hope this is helpfull...Good luck
Cheers
Techmor
Jun 18, 2009 | Gigabyte GA-8ST800 Motherboard
System hang when i insert pen drive
solution..
1) Check The USB Port for Damaged, Bend Or Broken Pins.
2) Check The Pen Drive For Physical Damage.
3) Try The Pen Drive In another USB Port. (i.e. if u r using the pen drive in the FRONT PANEL USB PORT than try it in BACK PANEL USB PORT)
4) Try The Pen Drive In Another System.
5) Tye Another Pen Drive.
6) If All Above Is Fine Then Format The PEN DRIVE.
7) Try The PEN DRIVE now.
8) Is Issue Still Persists Then..
9) Uninstall the CHIPSET/MOTHERBOARD DRIVER COMPLETELY and then clear %temp% & prefetch files and Restart Your System.
10) Install The Latest CHIPSET/MOTHERBOARD DRIVER and ANY AVAILABLE FIRMWARE for the motherboard..
May 22, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Front panel connections
The manual shows the correct pin outs, and can be downloaded here:
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=585
Jan 26, 2008 | MSI 915P Neo2 Platinum Motherboard
Intel Biostar P4TSE-D2 865 Chipset Mainboard for Pentium 4 533/800 FSB w/ 8X AGP and Serial ATA (MBSK478BIOP4TSED) Motherboard Logo
89 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
