Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Flashing red light
Tv turns on then after awhile it turns off and the light flashes red rapidly.
  • Philips Master
  • 8,457 Answers
Power board is dead,replaced the power board will get power back.
Posted on Jan 30, 2010
Giro plus - red light flashes rapidly, tried priming with no success. Anyone have any answers?
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
Sep 27, 2014 | Saeco Odea Giro Plus Coffee Maker
Constant flashing red light near on/off switch
i think it is the power supply board problem
Nov 05, 2013 | Televison & Video
Why does the red light om my 2002 crown vic flash fast when I attemp to start it
Which red light? The one on top of the dash? If so, there are two cases where that light will flash rapidly: If you use the wrong programmed key, it will immediately start flashing rapidly when you turn on the ignition and try to start the car. If the light is steady and then starts flashing rapidly after a few seconds when you turn on the ignition or try to start the car, you are using the correct programmed key but the engine computer has a problem or has failed.
May 31, 2012 | 2002 Ford Crown Victoria
Idisconected my battery for water pump have after market radio didnt think it would be a prob. but it turns over and will not start it has built in alarm and indicator light flashes rapid is there a way...
Insert ignition key,turn forwards to run. Just till red lights & theft/alarm light goes on. Do not try to start or engage starter.Leave on till light stops flashing. It may take up to 10 minutes. Once light stops flashing turn key off. Then start car & let run for awhile.
Mar 21, 2011 | Pontiac Grand Prix Cars & Trucks
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
Kdf42-we655 works for awhile then no sound or picture - standby light flashes for awhile then turns to red and flashes in sequences of 5 - then after a short bit tv comes up and works for awhile again. tv...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
276 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
