Question about Motorola Mobility i730 Cellular Phone
My phone wont hold a charge
I have a motorola i730 and it wont hold a charge, it will say charger or device attached but when I remove it after hours the phone beeps and says that it has a low battery! What should I do? Is it worth the money to replace whatever parts are needed or better to get a new phone?
    Scholar:
  • 43 Answers
Battery is done. Won't hold charge. Get a new battery at Fry's or elsewhere if your phone isn't ancient and you love it. Try to find a lithium-ion. I used to buy replacement batteries from Belkin on my older phones and they were quite good. If your phone is ancient, can't find battery or phone is just outdated get a new phone from your carrier. From free with new contract all the way to a few-hundred dollars for a smart phone. You may even have an upgrade discount waiting with your carrier. You'll find something in between that suits you.
Posted on Jan 30, 2010
  • 16 Answers
All you need is a new battery. which is about $5 on ebay. :)
Moto g wont turn on
Try holding down the power key for 30 seconds. You should see a white indicator light blink. If not then plug it into a charger that you know works. If your not using the original charger it may not be getting enough power. You may need to charge it for a couple of hours and then attempt to turn it on while on the charger by holding down the power button for atleast 30 secs or untill it turns on.
Sep 20, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
I have a problem getting my phone on. i have a motorola electricify. it wont turn on even when i try to reset it hold the volume down button. it wont do a thing. it wont charge. everytime i plug the c
Kyle
let it set on the charger for a couple hours without attempting to turn it on. See if the battery icon appears.
If that doesn't work you can try MOTOROLA ELECTRIFY Master Reset Factory Data Reset
Mark
Motorola Support
Sep 14, 2014 | Motorola Mobility MB853 Electrify US...
My Android 4 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 07, 2012 | Cell Phones
My phone will not charge. I can connect it to the charger and it looks like it is charging. Remove the charger then phone goes off. I charged the battery with a stand alone charger then installed battery....
It maybe a problem on the phone already and not on the battery. Something inside the power ic / board that's why any battery will not hold charge for long. Try also draining the battery and then charging it for a full 2 hours with the phone powered off as this charges the phone faster.
Mar 07, 2011 | Motorola Mobility MOTORAZR2 V9 Cellular...
How to unlock the motorola i730
Use the following steps to unlock your mobile....
1 - Switch ON your Motorola I730 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
And get the unlock code here theunlockarena.com
Sep 01, 2010 | Motorola Mobility FOR MOTOROLA NEXTEL I860...
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
I have a t-mobile simcard and is asking me for a lock code
If you are attempting to use a T-Mobile SIM card in a Nextel Motorola i730 mobile phone it will NOT work.
T-Mobile phones operate off of a GSM network. The Nextel i730 operates on an iDEN network.
The phone you have can never be compatible with the network you are trying to use it on.
Sep 07, 2009 | Motorola Mobility Naztech Nextel Iden...
I cannot get the sim card out of my motorola i730
Hello, please open this link: http://www.wonderhowto.com/how-to/video/how-to-operate-the-motorola-nextel-i730-mobile-phone-250239/view/
On that page click on SIM card Portability under Phone Feature...
If you are unable to remove the SIM card... then try to use a Tweezers.
Jul 14, 2009 | Motorola Mobility Naztech Nextel Iden...
Phone wont hold a charg and wont turn on
what you have to do is to clean your phone using isoprophyl alcohol i mean you clean the main mother board then you dry it using hair dryer ,after all that try to replace the battery it has reach it death neal the cells inside they are no longer able to hold the charge.advice by dogy.
Jan 04, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility i730 Cellular Phone Logo
91 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
