Maytag LAT 8506 filled with water then did nothing. It just made a humming noise. Is the motor shot? Chris
  • 770 Answers
Could be to find out remove the front panel(2 screws at the bottom) or....you can pull it a liitle from the wall tilt it back and look on the bottom to see if your belt is in tact first
Posted on Feb 17, 2008
When i close lid it just makes humming noise and wont start
If washer hums but doesn't fill, water isn't getting to washer check screens where fill hoses connect to washer. Screens may be blocked. If washer fills then hums check to make sure belt is on. Tip machine up to view belt underneath.
Sep 26, 2013 | Maytag Ensignia MAV2757AWW Top Load Washer
Dishwasher fills with hot water then does nothing
Do you get any humming noise when you turn it ON?
How long its been you used the dishwasher last time...?
If you are getting an humming noise then Sounds like the water circulator pump is stuck. The motor tries to turn it (humming noise), but cannot. So a breaker trips (self reset). Not claiming this is actually the problem, but this is what the motor turns.
Aug 30, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Will fill with cold water but not hot
the hot water inlet valve is shot replace it
Apr 27, 2010 | Maytag Atlantis MAV7551 Top Load Washer
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
LAT 9400 AAW no motorized funtions only fills up
The only other thing it would check is your pressure switch. This will case a no agitation issue. If you remove clear pressure switch tub from the tub and blow into it you should hear a click from the pressure switch. With power your motor may agitate. Also check to see if the tube is clogged. If the issue is not in your pressure switch then i would have to assume the problem is in the timer. If you can read the schematic (usually located behind the control panel you could check to see if you timer is sending 120v down to the motor.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Washing Machines
I have a maytag washer (model -dependable care) and when we start the wash the motor just hums, the water does not fill, if we move the timer switch to rinse the motor engages and the unit works entire the...
Check your fill tubes remove the hoses and see if the filters are plugged, you are not hearing the motor humming. You are hearing the watervalve humming, the motor will not start until the tube is full of water.
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
My washer won't fill with cold water...only the hot works.
Cold water solenoid on the water mixer valve is likely shot.
Change the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a maytag washer # LAT 9593 , washer fills with water very
Take off your hoses and check filters for sediment build up. If this is ok, you may need to replace the water inlet valve.
Feb 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Maytag washer will not agitate
ckd wiring connections motor and timer? if they look ok suspect timer ..motor contacts in timer may be shot
May 01, 2008 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
