Question about Panasonic NN-S763BF Microwave Oven
Lights up BUT does not cook
My three year old micowave has suddenly stopped cooking.
The digital readout reads normally. Upon typing in the time and heat and hitting the start button, the interior light comes on. The microwave shuts off after only a portion of the designated time has expired and the food or water being heated is still stone-cold. As a side note, there is not any noise to the microwave as there has been during any heating/cooking session.
I've pulled the cover and found that the door switch (behind the key pad) has bubbled and burnt. This switch was cleaned up and tested and continuity is still there. The internal fuse tests good.
I am capable to to the repairs correctly, myself. I just need a little guidance to get the job completed.
Many thanks!
  • 958 Answers
Was there any motor that should run as you turn it on, the fan inside and the rotating table motor. try to replace that micro switch at the door that bubbled out and burnt. try to test or replaced right away the industrial diode that is connected from the capacitor to the ground of the microwave.
Posted on Feb 18, 2008
Numeric keypad doesn't work on my microwave oven
if it got wet from cleaning just wait if its real old its more than not wore 0out
Mar 31, 2013 | LG Microwave Ovens
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
My two year old Frigidaire Microwave suddenly stopped cooking. All of the buttons work. The lights, the fan, the timer, and even the cooking timer operate. It's just that the light goes on and the timer...
Check the plug. If the vault is 110v or 220v etc.
If the plug seems to be right, but still not
working, you should buy a new one
with a good name brand you can trust.
It's better than paying for repairs and future repairs.
Mar 14, 2010 | Frigidaire FMV156DC Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Panasonic nn-s255 wont turn on
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Sep 08, 2009 | Panasonic NN-P295SF Microwave Oven
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
4205 stops after a few seconds, beeps, every segment of every digit lights up.
Sabotaged??? What could they mean by that?? It could be a bad control panel or connection, but I would say you have a bad magnetron, the magnetron is mounted loosely, or the RF gasket (mesh washer) on the magnetron is missing, loose or damaged. I would contact MayTag and see if they have a different authorized servicer in your area, or get on the phone and complain to them in great detail. Do not put up with this, please.
May 10, 2007 | Maytag MMV4205 Microwave Oven
Panasonic NN-S763BF Microwave Oven Logo
252 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
