Question about Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049
Compressor starts up fine the kicks out?
Starts up runs fine for about 6-7 seconds could this be the run capacitator?
thanks!
  • 494 Answers
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing....
Posted on Feb 14, 2010
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
My Bostich 6lb 2 HP oil free compressor was running fine until it kicked while I was using it as it sometimes does and would not stop. It actualy made a high pitch noise and began to smoke for a second...
The regulator on this model is prone to stripping and a kick would do it. Call the toll free number 800.556.6696 with your receipt and you should be able to get a replacement regulator.
Oct 19, 2010 | Stanley FactoryReconditioned Bostitch...
Fan runs fine, but compressor doesn't start-it hums for a few seconds, then kicks out. GE AHG40LAG2 serial AZ202478 dom 1/00 R12
The compressor has gone bad and will not start... what you he3ar is the compressor trying to start....it will probably cost you more to replace that compressor then buying a new unit...
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | GE AHG40LA Dehumidifier
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Newer kenmore elite trio refridgerator not cooling
The repair person came and in my case it was a start capacitator connected to the compressor. When he replaced the start capacitator the compressor came on immediately and started working. The charge $ 240 (Flat Rate) for the fix. The repair person told me its a universal start capacitator which I found online for $29. Worth trying to fix yourself before paying $240 if your a handy person.
Oct 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Refrigerator Compressor Inop.
I found this post by searching on the capacitor number, JSU21X126AQC. My 2001 Kenmore refrigerator (don't have model# here) compressor didn't run, but I heard it hum for a few seconds and then a click. That's the Klixon overload doing its job. I measured resistance of the compressor leads same as original poster. This lead me to determine that the windings were not open or shorted. The wiring to the compressor also fed the condenser fan, and it was running, so power was at least all the way to the compressor.
What I did find was that the 12uF capacitor was only 4uF. My digital volt meter has a capacitor check range. This compressor circuit is a permanent split capacitor type. Without the proper capacitance, the compressor can't start. I replaced it with a 10uF, 220v AC capacitor I had, and now it runs fine. I wonder how many refrigerators are scrapped because of this inexpensive problem?
Jan 22, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049 Logo
103 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
