Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I heard a clicking noise followed by on off water sound. Tonight it appears the refrigerator temp is not cooling and the temp lights are off. Food is still frozen but getting less so.
    President:
  • 1,515 Answers
Hi, The clicking sound is most likely the compressor relay, external start relay clicking on and off trying to start the compressor. For some reason it is overloaded causing this problem. You can pull the unit out from the wall and you should have a panel at the bottom you can remove. There will be a small condenser fan motor, a coil, and the compressor. If you find that the motor is not running and the temperature control is set for the unit to be on, this motor is the problem. You should be able to put you're hand on top of the compressor and do this carefully as it will be HOT. If the motor is running and the compressor is hot and clicking on and off, it is locked up and is faulty. It would be cheaper to purchase a new box then replace a compressor. You can get an estimate, but I do this every day and it could run as much as $1,800.00 to do this. Please check the things I have asked of you and get back to me and let me know what you have found.
Sincerely,
Shastalaker7
Posted on Jan 30, 2010
My kitchen aid refrigerator model kssc42qms02 making humming noises and the the temp lights are flashing
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
Apr 24, 2012 | KitchenAid Refrigerators
KA side by side 26.0.. 2 days ago temp alarm goes off,I hit the 'over temp reset'... appeared that the vent was blocked, so I cleared the vent area. Tonight, alarm activates again& I hit the...
Take a good look into the coil fins if you see dust get a fin brush and vacuum to control the dust and have at it. I have seen just dust cause your problem before.
Jul 03, 2011 | KitchenAid (KSRD22FKST) Side by Side...
I own a Whirlpool model WBM35LW refigerator, a buzzing noise lasts for about 10 seconds followed by a click. I replaced the start relay and overload but the buzzing continues, all seems normal including...
This is usually a sound coming from the ice maker solenoid. It will buzz while it is energized and letting water fill the tray up and then you will usually hear a clicking sound when it is cutoff and the water is stopped. Sometimes if the water line on the back of the unit is not secured properly you will hear various sounds as the water is suddenly stopped and the line moves around, like a garden hose does.
Sep 29, 2009 | Refrigerators
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Sounds like my fridge
ge main processing board part no# wr55x10052 that is the new factory updated control board that will sovle all you issues
Jun 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
162 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
