Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
My hp wont turn on..the power light is on but its like my laptop is frozen or somethng
    Guru:
  • 830 Answers
· First troubleshooting - When you turn the laptop on, are you able to see the splash screen? This would be the computer manufacturer's screen display that usually shows a picture but may also be text and usually appears right before the Windows logo screen. If the answer is yes, then more than likely, the operating system is corrupt. This can be caused by several things including viruses, power surges or hardware failure. If your computer hits the windows screen and reboots back into a loop, this is also signs of Windows being corrupt.
Solution - Take the hard drive out of the laptop and slave it to another working desktop computer to retrieve your data. You may need a special cable for this because the laptop hard drive is smaller than the cable in a desktop. This process can be done, taking precaution that both computers are off while slaving the hard drive. After you attach the hard drive, turn the desktop on, it will read it like another drive and you will be able to pull all of your information from it. You only want to grab the user files, not other data and run a scan to rid of viruses. Then attach the hard drive back on and reformat it.
· Second troubleshooting - If you hear the operating system chime but do not see a picture and all the lights are on, then this would indicate that the back light on the screen is out. You can test this simply by hooking the laptop up to a monitor and see if you get a picture. If the computer screen shows on the monitor, then your back-light is out. If it doesn't show up then your video graphics card is out.
Solution - If the back light is out, it is easier to order a new screen (new or used) from eBay and just switch out (simple process and you can find a replacement for under 50 dollars on eBay). If it is the video graphics card, then you can also purchase one from eBay and switch out (a little tougher because you have to take the top of the laptop off). You can get assistance with this from the manufacturers website (service manual) and pull specs for free.
· Third troubleshooting - To test the battery, take the battery out of the laptop and turn on with just the adaptor. If it boots, then the battery will need to be replaced. There is no way of testing the power adaptor but 85% of the time, this is the problem. Even if lights come on, the adaptor sometimes gets so overheated that it silently goes out but gives just enough power to make the lights come on. The power adaptor can be found on eBay for under 20 dollars and is cheap enough to replace (first) to make sure that is not the problem. The battery can also be found on eBay for under 60 dollars.
· Fourth troubleshooting - If you do not hear any beeps and the above solutions did not work. Then your motherboard has failed. This can be caused by surges or dust. You can purchase a replacement from eBay for a fraction of the cost and replace (this is tough and I am not sure if they have specs for this). You can do it yourself, just be sure and put everything back together as it was.
Posted on Jan 30, 2010
Orange light trying charge
I would try this:
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
I opened my computer and it was on, but the screen was frozen so I shut it down and tried to reboot it, but it wouldn't turn on. I thought it was something to do with the battery being dead, so I plugged...
It has something to do with the power supply of your unit or the motherboard itself, especially when you isolate the battery and plug only the power cable and i wont turn on. In this case, you can reseat the power supply by removing the cables and battery when the unit is off, remove the screws below it, remove the hard drive, remove the optical drive then remove the power supply and reseat it. Then perform the steps in descending order (insert optical, hard drive, screws, battery, cables). Turn it on and observe if there are lights lit on the keyboard. If you don't know how to do this or if symptom persists, consult HP tech support for repair of your laptop..
Aug 22, 2010 | HP Pavilion DV6775US 15.4" Entertainment...
Screen wont turn on
remove the battery and the power from the laptop.....then press and hold down the power button for 20 seconds ...... attach the AC power only and turn on the laptop this should turn on the system.
This drains the capacitors on the system (safety feature of laptops ... quite common)
If this does not work remove the Ram and reseat it ... something has either come loose or the backlight on the LCD has gone bad.
Oct 06, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Compaq laptop
its not charging try any other power adopter....
Jul 17, 2008 | HP Compaq Presario V2000 Notebook
Turn LAPTOP ON
push the screen to you and push it away so far as he can.
you hear a click the screen is fixed
May 14, 2008 | HP OmniBook XE3 Notebook
I need to turn on my wireless connection switch and dont know how or where it is
Please remember to always note Computer specifications in your problem requests; for example:HP Compaq 6310 Notebook.
Anyways; Look on your laptop (if it is a laptop) for a little button that has a little antennta with "little signals" coming from its sides. If you push that button, a light on your laptop should go on and you should see a "reaction" on your LT screen (your LT must be in windows though !!!) somethng like "Wireless network enabled" at the bottom right of your screen.
Kind Regards,
Stef
Apr 16, 2008 | Computers & Internet
Presario laptop frozen.
start ur pc in safe mode. if yes then u uninstall the display adapter.then restart ur pc in normally.plz report the result
Apr 01, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
144 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
