Question about Honeywell Programmable Thermostat Heater
Err 90 and 89
What does honeywell thermostat err 90and 89 mean?
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
Bae lo This is the message my electric Honeywell programable thermostat is flashing. It's still working. What's that mean? Thanks.
Try with this site:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Dec 12, 2010 | Heating & Cooling
How do you reset a honeywell th8110u1003 thermostat honeywell 800 # will not tell me but he said it needed to be reset because off ee code on screen
http://www.pexsupply.com/Honeywell-TH8110U1003-VisionPro-Thermostat-1-Heat-1-Cool-3909000-p YOU MAY FIND THE ANSWER HERE BUT IF NOT YOU CAN FIND IT RESET BUTTON IN THE (FURNACE?) UNIT. THE REASON HONEYWELL WILL NOT GIVE THE INFORMATION IS BECAUSE THIS CONDITION USUALLY MEANS THERE IS A PROBLEM IN THE SYSTEM AND GAS IS NOTHING TO FOOL AROUND WITH. FYI HAVE YOUR IGNITER CHECKED OUT.
Mar 05, 2010 | Honeywell Programmable Thermostat Heater
Thermostat not functioning correctly
-AC means there is no power coming from the furnace. not a tstat problem
Sep 24, 2009 | Honeywell Programmable Thermostat Heater
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Does blocking thermostat stop heating
you mean like putting a box over the thermostat? the air inside the "stat" will get to a temperature and stop the heating. when the temperature inside drops, the thermostat contacts close again and the heater starts again.
Nov 25, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
148 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
