Question about Husqvarna 965142201 K750 5HP 12" Gas Cut Off
Saw runs great then bogs down 20 sec. after i start cutting i let off it runs good then bogs again when cutting after a few sec
  • 25 Answers
Check your air filter, if clean chances are your carburetor needs to be rebuilt. the carburetor has thin diapragms that get hard and won't meter the fuel in fast enough.
Posted on Feb 11, 2010
Echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Nov 26, 2013 | ECHO, Inc. 20 In. Double Sided Hedge...
My saw runs good at idle and mid rang but when I stick it into a large limb and try to cut it bogs down and will die if I don't let go of the throttle. It acts as if it is starving for fuel. I tried to...
I have had to change a few fuel tank breathers on the 455 and 460 saws, when it starts to die try to slacken off the fuel filler cap, if it picks up again it is a brather issue, the breather is under the starter cover at the top right hand corner.
Sep 25, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
My Husqvarna 455 starts great and sounds great without pressure but when you put the saw under pressure of cutting it bogs down and runs up and down. I am not sure the problem. I have changed spark plug,...
If you haven't done so already I would run some spray carb cleaner through it. If the idle speed is okay then I would adjust high and low screws going very slowly about 1/16 of a turn at a time and run engine up and down after each adjustment. I would remove the muffler and clean the spark arresstor screen to get all the carbon deposits out of it.Carb. cleaner and a medium stiff wire brush work well for this. I would also check the vent in the gas cap to make sure it is open. I also use a product called sea foam in all my engines.For my chain saws I mix 5-6 ounces with 2 1/4 gallon of gas.It really does a good job of keeping everything internally clean. Hope this helps you. Thanks.
Jul 28, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Bought a new husky chainsaw a 455 rancher. was told i had to break it in on small logs & not run it very long at first. is this true
The factory usually recommends 2-3 tanks of fuel going easy on the saw and not running at full throttle.......but I have never done this on any of my saws and I don;t know anyone who has and my saws are all still running great.
May 20, 2011 | Garden
While cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Jan 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
When u start saw and start cutting saw dies down act like its flooding out
I think you are saying it starts and runs fine but bogs down when making a cut. If true turn the mixture screw marked "H" CCW ¼ turn and try it in a cut. Better? If not turn it CW 3/8 turn and try again. Careful CW is leaner; to lean will ruin your piston and cylinder. HTH
Lou
Dec 04, 2009 | Husqvarna Garden
Runs great for 30 sec. to 1 min. then dies slowly
Is it your chain saw Husqvarna 40?
Try carb adjustments H-3/4 turn ,L-2 turns and T a little higher
I presume that compression and ignition sistem is adequate for the engine to run.Good luck
mihai
Apr 04, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bogging down
Hi
The 2 stroke engines,your chain saw as well need to be check every year due to the carbon deposit from burning gases.Check if the engine is sealed properly(gaskets from carb,cilinder,crankcase and the seals.Pay attention at the flyweel key(not to be sheared off)crankshaft,piston,piston rings,piston rod.
regards savumihai71
Dec 06, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna 965142201 K750 5HP 12" Gas Cut Off Logo
530 people viewed this question
Top Husqvarna Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Husqvarna Measuring Tool and Sensor Expert? Answer questions, earn points and help others
