Question about Sony VPL-HS51A / VPL-HS60 Multimedia Projector
Sony VPL-HS50, any viewing (TV, DVD) a spread of blue appears on various parts of the screen, generally contained to the sides but from top to botom. Just recently a large yellow blotch appeared in the middle of the screen - projector is +6 years old. Thanks
  • 144 Answers
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
Posted on Jan 30, 2010
  • lancer11 Nov 27, 2010
    Exact same thing happening to me. Vertical Blue Streaks and a yellow splotch.
VPL-HS50 shuts down after few seconds
It must be a problem with electric connection. you should check whether it is OK or not. If it is okay, read instruction manual.
Jun 27, 2012 | Sony VPL-HS50 LCD Projector
I have changed the bulb on my Sony VPL-HS50 video projector and the image is now in black and white. I folloewd the instructions in the manual word for word. The bulb is a Sony genuine part
Is the buld u changed right and in working condition.please clean the optic lens and image CRT board which ( Scanner image board) to see if the issue remaisn or nott
Sep 28, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Blue Haze on screen Sony cineza vpl-hs50 projector
Its your blue polarizer going bad. This happens over time due to the excessive heat generated in the projector. The main problem is that your projector has organic LCD panels that degrade over time and in turn degrades your blue polarizer. The same thing happened to my sanyo Z2. It took 5 years for it to show on my Sanyo because I only use the projector for sports and movies. not daily tv watching. In any case, it isnt worth it to spend the money ti fix it...jut put tat towrds a new projector. The latest crop of LCD projectors almost all use in-organic LCD panels that last much longer. Hope this helps.
Aug 03, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
RESET, <==, ==>, ENTER.
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Feb 11, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony projector - replacement lamp counter
  • Set the projector in standby mode.
  • Press the following buttons on remote control in following order for less then five seconds each...
  • RESET,
  • ENTER
Lamp timer is reset now.
This is also mentioned in user manual page 50
Thank you.
Dec 12, 2008 | Sony LMP-H130 Projector Lamp Projector...
I also have the same problem -- the fix is to replace the optical block ( Internal lamp engine ) which is a $1,100 part. I just purchased a used projector for half the price of the part.
Nov 29, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Blue "Haze" at top of screen
My VPL-HS51 just started doing the same thing. There's a lot of similar reports out there and they all end up at the same bottom line - the problem is due to a design defect in the 'prism block' (LCD panel) and the only option, other than to throw it away or sell it for parts, is to pay Sony about $2300.00 to fix it. Good luck!
Dec 18, 2007 | Sony Cineza VPL HS2 Multimedia Projector
Blue tinting appearing on the right side of screen on vpl-es1 projector
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
May 13, 2007 | Sony VPL-ES1 Multimedia Projector
Sony VPL-HS51A / VPL-HS60 Multimedia Projector Logo
437 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
