Question about Compaq tc4400 Tablet PC
I just cannot use my pen to write on the sticky notes
  • 2,517 Answers
Dear friend,
1st of all you does not explain your problem in details. What ever if your does not used your digital pen then dont warry , just uninstall the driver and restart the laptop. Again run the setup. after finish restart laptop then try to use. hope you get good result.
Posted on Jan 30, 2010
The pen on my Samsung Galaxy tab 3 only works sporadically. ..... it'll start recognising threw pen when it's about 2 inches away from the tablet...... there are some spots. .....s note mainly. ..... that...
you mean galaxy note 3 .first be sure the pen has a nib in it not a hole where one has fallen out. then it is about 1/16th or so outof the pen and rounded next try replacing the pen nib your phone came with a packet of replacements. they pull out and are snapped back in. Last and for sure , there is actually a battery inside the pen if it is old and weak you will have to get another pen say from ebay (best price) but before you do go to phone store and use one of theirs to test . if you have the same problem and only certain spots do not work on the screen then your digitizer screen is in need of replacement. also another ebay cheapest item. but whatever it turns out to be it is fixable. come back if you need advice will check every couple weeks.
So pen has nib , or nib needs replacement,pen has weak battery and need replacement or digitizer needs replacement. all solutions are under 100 dollars most under 50 . no nibs or bad nibs under 15.
Dec 23, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Using stylus on Galaxy Tab 3 10.1
The tab isn't compatible with the s pen only the note series of tablets have them.
Mar 18, 2014 | Samsung Galaxy Tab (GTP1010CWAXAR)
My slate vision tablet pc is having some problems. The screen is not reacting when the pen touches the screen. I went into the control panel seems that everything set up correctly. Could it be the pen that...
Your tablet pc uses the Wacom Digitizer so the pen does not use a battery. It is possible that it could be the pen or the screen. It works with electromagnetic resonance technology and the screen produces this signal that the pen grabs, converts, and returns to the screen without batteries. The pen does contain compenents that can fail but so does the screen. You could try buying a replacement pen for around $20 dollars and see if that works. Worst case you would be out $20. If you had another tablet PC that uses a Wacom screen you could try the pen with that one or test the other pen with yours.
Sep 28, 2009 | FIC SlateVision Tablet PC
I cannot even find the eraser in one note
In One Note 2003, the eraser is to the right of the pen.
If for some reason you cannot see it anymore, you may reset ONE NOTE to its default options.
To do that (for ON2003) you click Help>Detect and Repair. In the window that pops up put a check mark in the box Discard my customized settings and restore default settings.
This should restore your toolbar.
Better yet, look for the small down arrow (with tooltip :toolbar options) and click it.
>Add remove buttons >Standard .
In the window that unfolds, make sure that the eraser is cheked. (For OneNote2003)
Hope it helps
Aug 21, 2009 | Motion Computing M1300 Tablet PC
Exact same problem!
Well, I couldn't find how to make hand written notes in Word. I did find this.
Windows Journal Scroll down the page till you get to the Windows Journal section.
Pen Office Third party software that allows you to make notes in Word.
Please don't forget to rate this solution.
Jun 17, 2009 | Gateway CX200X Tablet PC
My pen for my computer won't work
I think the pen has gone bad on you, since your screen can still detect your hand and the track pad. I would think the pen is faulty. Try another pen cause I think your original is bad, if it was the touch feature that wasn't working I would say its a driver problem but that feature still works with the exception of the pen. Get another pen.
May 31, 2009 | Dell Latitude XT Laptop Computer Tablet...
Lenovo X61 Tablet pen not functioning
Same here this sounds weird but you have to hit the screen with the pen.. in the long run it probably hurts the pc, but it fixes the problem.
Apr 28, 2009 | Lenovo ThinkPad X61 Tablet
Pen doesn't work
have u tried re-installing the driver... if thats the case even if u tried different pens it wouldnt work... plus even if ur driver was fine a different pen wouldnt work for that driver... after re-installation if the pen still doesnt work then theres a 50% chance ur pens not working... One more thing does ur monitor support it???
Aug 30, 2008 | Eaton 30311 Tablet PC
The Pen
I'm not familiar with your laptop but judging from all the pdas I've had with touch screens the pen itself is only a pen, you could basicly use a wooden stick to poke at the screen and it shouldn't make a difference to the computer.
this laptop has a touchscreen If I'm not mistaken and you should be able to use it even with your fingers.
You might have a faulty touchscreen or then you need to install a driver for the screen?
Jul 04, 2008 | Averatec 3500T60 Tablet PC
Gateway tablet screen does not respond to pen.
I have a Gateway CX2724 and previously had another Gateway tablet (model I don't remember) but they both look alike and use the same pens. I've had 3 pens and they all periodically stop working. When one stops, I pick up another pen and work with it so that makes me think the problem has more to do with the pen. (They have all died and later come alive.) Sometimes though I can't find the extra pen and have resorted to removing the working pen tip / nib and reinserting it very snugly after wiping off the shaft. The nib is held in merely by friction. You can remove it by pinching its little tip between your fingernails and pulling it straight out. I wipe off the shaft and put it snugly back in. Sometimes I don't take it out, but just press it harder into the pen by pushing it firmly onto a padded surface (so that the tip doesn't deform.) Usually one of these "treatments" works. I know that extra nibs are available with the pen. There must be some reason that the manufacturer thinks they may need to be replaced periodically. But I've never seen any documentation on this.
Sep 30, 2007 | Gateway M275 Tablet PC
Compaq tc4400 Tablet PC Logo
120 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
