Question about Brother MFC 7840W Printer
When I scane a document,how to put in a PDF file.
You go to HP Solution Center ( it will be on your desktop as shortcut maybe) and choose settings, then choose Scan settings. Here you will have the option scan document settings. Click on this and inside you will find a question "where do you want to send the scanned image" and the option to choose FIle type. The file type can scroll to PDF among other options.
Posted on Jan 30, 2010
Tip
Scan multi-paged document and create a single PDF document
1. You need to install a PDF printer driver on your computer first.
There are quite a few freeware PDF writer programs on the Internet you can download one such as CutePDF.
To download CutePDF printer driver (freeware) click on this link :-
http://www.cutepdf.com/
2. Using your computer SCAN the first page then click on File - Save the image as a jpg file Eg. image1.jpg
4. Repeat step 3 for the other pages.
5. Close the scanner when finished scaning.
6. Open a Word document then place each image file on a new page in the Word document
7. Save the Word document if you require but not needed.
8. Click on File - Print then select CutePDF printer (or your PDF printer driver) and save the PDF file. This PDF file will contain the multiple pages of the scanned pages.
on Jul 07, 2011 | Computers & Internet
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
Is it possible to scan PDF on the HP C4210 All in one printer? How? As well, can we save to scaned pages as 1 doc? Thank you
You need to have HP Solution Center Software installed on your computer to scan to pdf.
Open up HP Solution Center program.
Click on scan document.
Another window open with Document to PDF File highlighted in blue
Click on SCAN box.
Jan 01, 2014 | HP C4210 Printer
Hi! My matchine is scaning all documents in Grayscale by def
yep!
sorry but our panasonic dp-8035 is only black&white document scanner.
Jan 14, 2010 | Panasonic DP-8035 Grayscale Copier
HP Deskject All-In-One Scanner Problem
try from program if you have it installed on your computer, look in my documents , my scan directory that is in most cases default directry for scaned files. But try from program ( software which you have with your all in one)
May 08, 2009 | HP DeskJet F380 All-In-One Printer
Scan document to pdf format
you have to set up on the machine to scan to SMB. you then creat a folder in your c drive to recieve the scaned documents the folder needs to be a shared folder and you have the option to recieve it im PDF format.     let me know if that helps you out.
Feb 11, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Scan a Multipage Document into a Single File
My scanner is a Cannon but the basic jist of what your trying to do is universal. You need to open up the software for the scanner and look for an icon that says scan to file. It sounds like you have already done this. If so you are very close in the step I mention to the setting you need to scan multiple pages into one PDF file. Once you find the setting to scan multiple pages be sure to not click "FINISHED" until your last page is scanned in.
LB
Nov 30, 2008 | HP ScanJet 2400 Flatbed Scanner
Brother MFC 7840W Printer Logo
330 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
