Question about Pioneer Audio Players & Recorders
I have a SX838 Pioneer Receiver. How do I hook up a SG9500 Pioneer Equalizer to it?
  • 4,234 Answers
The EQ should be connected between the pre-out and the Amp-in.
The pre-out goes to the EQ input.
Dan
Posted on Feb 03, 2010
Can you hook up a pyramid graphic equalizer 8600 to a Pioneer receiver audio video multi-channel vsx - D 912
The ideal way to do it is to hook up the preamp outputs of receiver directly to equalizer and the equalizer outputs to the amp inputs on receiver. Then unit will work with all sources.
Jun 30, 2016 | Pioneer Audio Players & Recorders
How to hook up a pioneer 7 band gr 470 equalizer to a Kenwood kr-v6030 receiver
Connect one pair of RCA cables between the receiver and equalizer. Connect one pair of cables to the pre-amp output channels on the receiver and the other end of the cable to the left and right channel inputs on the equalizer. You will usually find these channels on the rear of the equalizer.
May 09, 2016 | Pioneer Audio Players & Recorders
How do I connect Pioneer equalizer SG9500 to a Sony STR-K740P and Sony CD DVP NC600?
Equalizers can be hooked up two stereos a few different ways. If your receiver or amplifier has what's called a processor loop that is where you would connect the output of the processor to the input of the DEQ and then the output of the processor loop to the input of the Eq. This would be visible on the back as for RCA jacks either with a selector switch above to determine whether you want to use the loop or not or jumpers that go from one of the RCA's into the other input to output for when you're not using that loop. The other way would be to connect it to the input and output for a cassette deck you would hook it up the same way however that would depend on whether your receiver has a separate tape monitor button. If your receiver let's say is In FM mode and you press tape and it still shows FM on but an indicator for tape Mon comes on as well then it will work OK. But, if you must switch off of FM to put on the tape Mon. You prob won't be able to use an eq with that receiver. Then your only other option would be to put the eq between a source such as CD....etc and the input for that source barring phono.
Aug 16, 2015 | Sony Audio Players & Recorders
Im having trouble hooking up my equalizer to my Pioneer audio/video multichannel receiver vsx-814
Looking at the back..bottom right corner is CDR/Tape in and out. Connect the in on the eq to the out of CDR/tape, connect the out of the eq to the in of CDR/tape.
You should then be able to use the CDR/tape monitor button to switch the equalizer in and out.
Sep 25, 2014 | Pioneer Audio Players & Recorders
I have a pioneer VSX D-308 RECIEVER and a electro-voiceevt 2210can it be hooked up together
The Tapco equalizer was a very popular line of equipment which was eventually bought up by Electro-Voice. Could not find any online manuals, however found online images of back panel. It appears to have Tape Ins & Outs.
Unfortunately the equalizer you have is not compatible with the receiver unless you have special cables that have built in transformers. This unit has T&R connectors (tip & ring) meant for professional sound equipment.
On a typical home stereo receiver you would hook up your equalizer with RCA connectors as follows.
1) You take the output of the equalizer and plug it into the input of the receiver.
2) You take the output of the Receiver and plug it into the input of the equalizer.
Start with lower volume and your tape switch on the receiver to the on position. Play with the various controls on your equalizer to
Apr 17, 2014 | Electro-Voice Tapco Graphic Equalizer,...
I cant seem to hook my pioneer gr 470 equalizer to my pioneer receiver ( vsx-403) what is the proper connection sequence?
tape out from reciever to line in on the eq --then line out from the eq to tape in on the reciever --whenever the tape monitor will be used on the reciever the sound will then be equalized
Sep 02, 2010 | Pioneer GR-470 Home Equalizer
I have an ADC equalizer model # SS-100SL i'm
record out-------equalizer in-------equalizer out------tape in
Mar 01, 2009 | Audio Players & Recorders
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Nov 29, 2007 | Spectrum Technical Hifi EQ-B5100...
197 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
