Question about Dell Inspiron 5160 Notebook
I got a message saying hibernating and the system shut off. does not boot up again
Not booting but power button flash
Since you didn't tell us what kind of laptop you have, or what system you're running, we can only guess.
If the power button is flashing, usually it means the laptop is asleep or in hibernation mode. Check your laptop's documentation on how to wake it up, or bring it out of hibernation. On some models, you can press and hold the power button to shut it down then power it on again.
Hope this helps. Please rate my response
Randy
Aug 31, 2012 | Computers & Internet
Tip
How to start up faster, via enabling hibernation on your notebook.
Starting up much faster. When your computer hibernate, it stores whatever it has in the memory to the hard drive and then shut down. Once you power up again your computer come out of hibernation and return to it previous stated, and therefore booting up faster.
To enable hibernation on your computer do the following: On your desktop right click then go to properties, once in properties then go to Screen saver tab in there chose monitor power button. Once in the monitor power chose the tap for hibernation, then enable hibernation.
on Jan 21, 2010 | Computers & Internet
Tip
HIBERNATION
THE OPERATING SYSTEMS WHICH THE MICROSOFT HAVE PRESENTED TO US HAVE MANY ADVANTAGES AND NOW I AM SHARING ONE WITH YOU FRIENDS.
WHEN WE ARE DOING A TASK,IF WE WANT TO GO FOR ANOTHER WORK LEAVING THE COMPUTER ALONE,WE USUALLY SAVE THE WORK AND SHUTDOWN THE SYSTEM AND GO FOR THE NEW WORK.BY A SIMPLE TECHNIQUE THIS CAN BE AVOIDED AND WE CAN REENTER INTO THE WORK WHICH WE WHERE DOING BEFORE SHUTDOWN.THIS FEATURE IS CALLED HIBERNATION.THE STEPS TO DO THIS IS THE FOLLOWING.
1.Click Start
2.Select Settings-Control panel- Power options-Hibernate- Enable hibernation.
3.The system can be left to hibernate by selecting the turnoff option,then point the mouse to the stand by option and by pressing down the shift key,select it,then you can see the option as hibernate and select it.Then you can see instead of shutting down windows,it gives the message as hibernating.Then it is ready,then you can return to the work by again pressing the main power switch of the CPU.Try it and look how amazing it is.
WARNING:First go for a trial with open windows(2 or 3......) and then try in actual practice.Does not cause any failure to the system 100% safe operation.Thank you
on Dec 28, 2008 | Microsoft Windows XP Home Edition
Dropped laptop today, switched it on and it starts up, but comes up with black screen with following message: Boot from AHCI CD Rom: operating system not found But before that screen comes up...
It sounds like you might have damaged your HDD when you dropped it. It's saying that the operating system isn't found, and it's trying to boot from your CD ROM. Either that or you might have left a disk in the CD drive, I'm guessing that is unlikely but worth checking maybe. By pressing F2 at start up and going into your BIOS (the Phoenix SecureCore Setup you talked about) Without changing any settings look through it until you find the HDD, or the BOOT options, if it lists a HDD don't get excited as it should be there even if it was damaged and is now unusable. Did you have your laptop on Hibernate, they say to shut them down if your transporting. Since when they are off they park the HDD, but when they are in Hibernate the HDD really isn't off it's on stand by. Making it easy to damage since the HDD is ready to read or write at the click of a button.
Aug 04, 2011 | Computers & Internet
Should I Leave my PC in sleep mode after use?
Go green & use hibernate instead.
Well, actually a lot also depends upon what is the duration of you not using the system between breaks. Hibernate anyways is quicker than a normal boot process. I would highly recommend hibernate.
Sleep - is a combination of stand by and hibernate. Be default most of the newer system will write the memory info into hibernation file & put your system to stand by mode. After certain period say 2-3 hours your system will go into hibernate mode. (these are standard settings & unless you keep coming back in 15-20 mins you should use hibernate & contribute towards environment too)
Oct 07, 2010 | Computers & Internet
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
Computer is not starting up in standard windows mode. dell media keeps popping up and when i exit the program my pc shuts down. i tried ctrl and f8 it brings me to a short menu. (1) continue restart...
Are you running Window XP? Is your computer set to hibernate? If so, you may have a hibernation error...
If I understand correctly, while pressing F8 during bootup you received a message that states:
"System restart has been paused:
Continue with system restart.
Delete restoration data and proceed to system boot menu"
You may wish to read this article about the error. http://support.microsoft.com/kb/294427
Then, go ahead and do that second option. What hibernate does is write a big file to the HD with the exact state of Windows. That is a "restoration" file. If hibernate doesn't work, deleting the restoration file will often allow the computer to restart normally.
Good luck! Please post back with your results.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | Dell Inspiron 1420 Notebook
Shutting down ,HIbernating
open control panel then display then click screen saver
then power at bottom of page In there you will find Hibernate and other settings that you can change you can disable able hibernate standby and sleep
Then click apply
restart let me know if this was helpful
Jan 19, 2009 | HP Pavilion dv9000z Notebook
PC won't wake up after Hibernate, Standby or Restart
You need to take off your hibernation.
In control panel display then screensaver.Then click power at the bottom of that screen.
You'll see a setting for system standby you can set that to never.At the top click on hibernate remove the check in enable hibernation.
Click apply restart and your system should work.
Jan 12, 2009 | IBM ThinkPad R40 2722 Notebook
By-pass Hibernation
Instructions: Power off the system and wait a few seconds to make sure that hard drive has spun down. Hold down the "Backspace" key while powering on system. The following message should appear: Warning: Can't restore Hibernated State. Press any key to continue. After pressing a key on the keyboard, the system will continue with the boot process and the hibernation/standby mode will be by-passed.
Sep 07, 2005 | Toshiba e740 Pocket PC
Dell Inspiron 5160 Notebook Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
