Question about HP Hewlett Packard LaserJet 2605dn Printer
I recently got windows 7 and i have a hp 2605dn laserjet printer. for some reason, pictures with red are faded. just replaced with a new cartidge and still have problem is there any special color settings i should have
    Novelist:
  • 217 Answers
The recent Windows 7 is probably just a coincedence.
This is a common problem on these printers.
Cause is dirty lenses and or mirrors in the laser unit.
Solution is remove laser unit, open it, clean lenses and mirrors (very carefully to avoid disturbing alignments, and scratching).
The laser unit is deep in the printer, so it's quite a lot of work, but very rewarding when you've fixed it.
Alternatives - buy a replacement laser unit and swap and clean old one at leisure, or get an exchange refurb printer - if you think your mechanical skills arn't up to it.
Posted on Apr 05, 2010
Hp color laserjet 2605dtn driver windows 7 32bit
** Fixed **
I got my problem solved by followed below article steps.
http://printer-driver-download.us/hp-color-laserjet-2605dn-driver-download/
Thanks
Oct 04, 2012 | HP LaserJet 2605DTN Color Printer
Cannot install hp color laserjet 2605dn printer in windows 7
Specific print driver and software information for printing in Win 7 is available for HP LaserJet, Color LaserJet and LaserJet MFP products.
This printer cannot be installed with installation disc or download.
May i know what is the error message that you get while installing.
Aug 19, 2010 | HP Laserjet 2605 Printer
�Hp laserjet 1600 red color print out very low (new cartridge)
- the problem might be with the laser/scanner assembly of the printer, it is probably dirty
- http://www.formyfriendswithmacs.com/images/don-thompson-2605dn.pdf
- refer to an HP Authorized Service Provider to solve the problem
Aug 01, 2010 | HP LaserJet 1600 Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
I replaced the color cartridges and the color is still very faint - almost illegible. What is wrong?
The scanner inside the printer needs to be cleaned I have done this on several of my 2605dn. Just google around and there is instructions on how to do this. Google: Fading Red Tones on Color LaserJet 2600s; Don Thompson's Service Seminars has a document that tells you how you do this cleaning.
Apr 21, 2010 | HP Color LaserJet 2600n Printer
2605dn says "replace supplies" points to black
You might have an issue with the cartridge lockers. Be sure to clean cartridge contacts and HV pins in printer. Doesn't help? Do like this. In the printers menu, under system set up, then print quality, then replace supplies there you can choose override out. Print a status page and check status for the cartridges, if the printer don't prints in override mode you have a brooken cartidge locker. In that case, remove all toner cartridges and check the lockers by moving cartridgedoor in and out, do all works the same way or is any of them different?
Dec 05, 2008 | HP LaserJet 2605dn Printer
HP 2605dn laser - color fading
HP has a list of troubleshooting steps you can go through for the HP 2605dn when you experience print quality issues.
Two specific things I would try from that list are:
  1. Clean the electrostatic transfer belt.
  2. Clean the printer paper path.
Good Luck!
*If you find the solution helpful, please rate it!*
May 15, 2008 | HP Color LaserJet 2600n Printer
2605dn prints red background randomly
n the Windows environment, the Automatic and Manual color options are on the Color tab in the printer driver. choose manual and click on grayscale
Jan 09, 2008 | HP Color LaserJet 2600n Printer
Colors are uneven, too much green on the right side and too much red on the left
The internal optics are dirty. It's a known problem that HP's been ignoring.  More info is here:  http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1202453734788+28353475&threadId=1073731
Detailed instructions are on this page - look for Don Thompson's posting at Sep 15, 2007 23:38:51 GMT and click the papercliip to see the procedure. It's not for the faint of heart.
Dec 12, 2007 | HP Color LaserJet 2600n Printer
HP Hewlett Packard LaserJet 2605dn Printer Logo
232 people viewed this question
Seeker5211
Seeker5211
