Question about Mitsubishi SD110R DLP Projector
Mitsubishi SD110r DLP Projector won't work
Mitsubishi SD110r DLP Projector:: turn on, two greens, then p:red/s:flashing green, then p:red/s:off... no function. ?
  • 144 Answers
Your bulb could have blown, Your projector could have died
Posted on Jan 30, 2010
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
Tv light blinks green then solid then red
Hello:
From the sound of your description of your problem you likely have a defective lamp. Feel free to give us a call at 866-764-5822 and we would be happy to help you troubleshoot the problem over the telephone.
Best Regards
Dan
DLP Lamps Projector Lamps Specialty Lighting
Mar 31, 2014 | Mitsubishi WD Televison & Video
Problem with Sanyo Mitsubishi XD-2000u status light flashing green then red. Lamp does not come on
The two most likely causes are either lamp failure, which is especially likely if the projector has been used in a portable capacity and moved whilst running, or another equally likely culprit will be that one of the cooling fans may not be starting up. You may be able to see this when you turn it on - if the blades of any of the cooling fans either do not move, or move only slightly and stop, then this will be causing the control system to shut down the projector
If it is neither of these causes, then it will most probably be either a temperature sensor or power supply fault
Nov 12, 2013 | Mitsubishi Xd2000u Dlp Projector
Colour balance
does it look like that when you view the menu? Across all sources?
Apr 23, 2013 | Mitsubishi XD510U DLP Projector
The problem with my projector is it keeps flashing green and red
hi,
your statement is not very specific but if the power led is flashing green and the lamp led is flashing red that indicates a fan failure.
contact optoma support here and enquire if you can have a warranty repair, or how much it may cost to have the fault fixed.
Feb 14, 2011 | Optoma HD65 DLP Projector
Mitsubushi DLP Projector Problem
I am having the same problem with mine.
Jun 23, 2009 | Mitsubishi HD1000U DLP Projector
Projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Feb 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Mitsubishi SD110R DLP Projector Logo
256 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
