Question about Uniden Cordless Phone
Both phones show "line in use". I've taken out the batteries, unplugged the AC cord and phone line - nothing works - any other suggestions?
Hello, tankes for tips nokia phone formattig.
Posted on Jan 30, 2010
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
My KX-TG6511 Phone is in it's cradle but line in use message shows. It's the only one on that line
Check your phone line with a) a new cord between the base and the jack and b) a different phone (I prefer an old cordless phone). If you still get a "line in use" message (alternate errors: fast busy signal or no dial tone), use your test phone at a different jack and determine if the issue persists. If you can, find where your phone service comes in and open the box. If you are lucky and have a fairly new service connection, you'll be able to plug your RJ-11 phone line in and check if there is the problem is at the box. If you can't test at this point, you need to contact your phone company to diagnose if the problem is inside or outside.
If the problem is only with the KX-TG65111 phone, try unplugging the base from the phone line and the cord from the wall jack, disconnecting the base AC power cord (from both sides - phone first) and removing the batteries the handset. After a few minutes, plug in phone line, power cord and batteries and test again. If it still fails, then the phone needs service. These cordless phones are not designed for the home user to service. If the phone is under warranty, contact Panasonic. Otherwise, decide if it is worth having the unit serviced or replacing.
If no phone works at this one jack but does work at another jack, you have a wiring problem at the jack or in the wall to the jack. Try opening up the outlet and check for loose or damaged wires. The jack is either wired directly to screw terminals or punch down terminals. For the screws, it's relatively easy to strip the insulation and retighten the connections. For the punch down style, you will need the appropriate tool. (It's available from many hardware stores in the wiring section.) See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the pins in the jack wiring.
If none of your inside jacks work, look at the exposed wiring and check for any obvious damage. Otherwise, you'll need to find the problem in the walls. You may want a professional to do the job.
If the problem is outside, your phone company will fix the probem for you for free. If the problem is inside, they'll fix the problem for a fee.
If you have a DSL line and a filter on the line, check and replace that if it is part of your inside wiring.
I hope this helps.
(I've gotten a line in use error with a DSL filter problem after a nearby lightning strike. Since my filter is inside the service box, my telephone company handled the repair.)
Nov 21, 2011 | Panasonic KX TG6511 Cordless Phone
We have a five (5) phone on one line with Uniden. We have checked all the outlets and everything seems in order. We can not get a line on the system. Help
The following tips come fromUniden.com website, hope this helps you. Question: What are things that I can check or do to get myphone working properly?
Answer:
1.Make sure phone is not sharing an ac outlet with any other types of electronicequipment. 2. Make sure base ac adapter is not sharing a multi outlet plug. 3. Make sure phone cord is not plugged into a splitter, fax, computer or remoteanswering machine. 4. Check to see if the phone cord is plugged in properly. 5. Check to see if the AC Adapter has been properly plugged in, the outlet is onand working. 6. Make sure phone jack is working. 7. Phone cord needs to be plugged directly into phone jack to insure optimalperformance. 8. Make sure you are using the original ac adapter that came with the unit. (Itshould say Uniden on it) 9. Make sure proper battery is being used .(It should be the one that camewith the unit, or a new Uniden battery) 10. Make sure battery is installed and plugged in all the way.( It shouldclick in) 11. Move phone to a different location in the home. (Different phone jack) 12. Disconnect AC Adapter and reconnect it After 25 seconds. 13. Reset the Digital Security Code if applicable - instructions can be found inowner's manual if applicable 14. If nothing else has worked. You can see if a basic reset will work on thephone. A reset is done by following the below steps:
a. Disconnect Battery from handset(s)
b. Disconnect Phone Cord from wall jack
c. Disconnect Phone cord from base unit
d. Disconnect AC adapter from wall outlet
e. Allow to sit for 30 min
f. Reconnect Phone Cord to base
g. Reconnect Phone cord to wall jack
h. Reconnect AC Adapter to wall outlet
i. Reconnect Battery to handset until you click or feel the plug snap intoplace
j. Re-Register Handset by placing on main base (Resetting security code -manually) 15. Check to see if you are on tone dialing or pulse dialing. 16. If you are still experiencing problems please call USAcustomer service at 1-800-297-1023, please tell them that a basic systemreset has already been completed and what the issues are still.
If you are in Australiaplease call: 1300 366 895 for all Service queries including producttroubleshooting.
Contact details for Uniden in other countries can be found at:
http://www.uniden.com/about/locations.cfm
Mar 14, 2011 | Uniden Cell Phones
Stopped showing pictures stays blank
Try resetting your phone. Unplug from the power outlet and unhook the phone line, then if your phone have batteries remove the batteries wait after that wait for 10 - 15 minutes. Then put verything back in in reverse order. So the batteries goes in first the phone line and then plug the power cord to the power outlet. If this doesn't work try to check the warranty and call the manufacturer to have it replaced.
Sep 09, 2010 | Thomson Lands Phones
No dial tone.
make sure the line is connected right try replacing the cord or maby the lines in your area are down out of service this happens
Mar 08, 2009 | Uniden Cordless Phone
Phone does not work
I had exactly the same problem. I tried re-registering the handset several times with no change. In desperation, I took the battery out of the handset for a minute or so and unplugged the transformer from the wall. I reinstalled the battery and plugged the transformer back in and voila! The phone now works! No guarantees that it will work for everyone, but it worked for me.
Dec 15, 2007 | Lands Phones
Phone or fax doesn't work
check there is power in machine. bye
Sep 25, 2007 | Brother MFC-620CN multifunction Color...
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Can't hear caller
This problem often results from a defective handset cord--check the handset cord by switching it with a good one. If that solves the problem, replace the cord. With a portable phone, substitute a transmitter from another telephone--replace if necessary.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
Uniden Cordless Phone Logo
50 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
