Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My Singer Futura keeps telling me that I have installed the small hoop and need to change it to the large hoop...but I have actually installed the large hoop. It is giving me an incorrect error message. I have tried to take off and replace the large hoop but nothing changes. I just keep getting the same message?
I have the same problem. I can not get rid of the error. I've called the 1-800 singer support and they told me to take it in for service. Would like to know if there is away to correct without taking into have serviced.
Posted on Nov 11, 2015
  • 64 Answers
Make sure you have the latest software version. Current version you may check in About dialog under Help submenu and in the same submenu you wil find a function Live Update.
Also make sure you switch on the sewing machine either with the large hoop connected or without hoop. If sewing machine was switched on with the small hoop attached, it will provide this error message about wrong hoop.
Posted on Jan 30, 2010
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from www.futura-support.com. If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
SINGER QUARTET FOUR IN ONE HOOP ERROR
There are a couple of reasons that this can happen. First, download a patch on the singer Futura support site, www.futura-support.com. Download the patch, close the Futura program and double-click on the downloaded file. It may help with your error.
The second reason it can happen is because the USB plug on these machine is out a little too far, and the cable often doesn't seat quite as solidly as it should. Put the cable plug in the machine, making sure that it sits squarely and securely, and tape it in. When you unplug, do so from the computer side and leave it in
If you've applied the patch and taped the plug, the third reason might be the USB cable itself might have a loose wire, so that it works some time but not all the time. If that seems to be the case, try another cable.
Aug 05, 2014 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
I'm having problems with my singer futura quartet seqs-6000. While embroidering the machine begins to stich but the hoop does not move so all the thread gets caught under it in the bobbin. how do I f
for the hoop, you could turn off the machine and restart, or put in the big hoop and then select the small hoop for ur design. and get some TCL on all the bumps by joining the future group on FB. and don't forget to "pay it forward" back here on this site.
Nov 16, 2013 | Singer Sewing Machines
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Feb 05, 2010 | Singer CE-200 Quantum Futura Computerized...
WHEN I SEND DESIGN TO MACHINE MY HOOP DOES NOT GO TO THE RIGHT PLACE THIS IS A EMBORIDY SEWING MACHINE SINGER FUTURA
Keep trying. I read on the Future web site, that there is an "order" to staring. The software assumes you are using the large hoop. Every thing needs to be in place, before you turn the Future software on. Then the hoop should move to the correct portion. I just get mad and move it by hand. Check out the FAQ on the web site.
Aug 15, 2009 | Singer CE-100 Futura Computerized Sewing...
Hoop errors
I have the same machine 1 year old ,check thet the hoop is on pins correctly and tight and that the large hoop is selected on the program.as these machins are verry sensetive.Hope this helps.
Lea
Jan 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer Futura CE 150 not recognizing small hoop
Except advices from the previous posts I suggest to check out whether you install small hoop precisely, there should not be any deflections, you need to insert it on the full length and fix it very well.
Sep 06, 2008 | Singer CE-100 Futura Computerized Sewing...
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
368 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
