Question about Linksys Wireless-G WRT54GL Router
The guy at the phone company chnged 1 digit of the ip address to set it up and the power went out and its not working again. how do i get to the screen where he made this change?
  • Linksys Master
  • 2,263 Answers
Is there ny computer connected to the router ?
If not then you will need to connect the computer to the router. check the IP address on the computer . default gateway will be the number that you can use to open the router page. On the router page you can change the settings of the router.
Make sure that your computer is able to go online when connected directly to the modem.
Click here for more information about the router and network
Posted on Jan 30, 2010
Unlock Panasonic KX-TSC35SUW Digital Telephone System
Not sure if this would help, but won't hurt to try..
1.
Connect to the Web UI
a.
Connect the Phone and a PC to the network
b.
Check the IP address of the phone using a handset.
[Menu]->[IP Service]->[Network
Setting]->[IP Settings]
c.
Enable the phone's Web UI using a handset
[Menu]->[IP Service]->[Network Setti
ng]->[Embedded Web]->[On]->[Save]
d.
Enter the IP address in a PC's Web Browser.
example: Enter "http://192.168.1.68"
in the address bar of Internet
Explorer
e.
Enter Authentication ID and password
Password:cspass
f.
Now you can upload new Firmware
into the phone using Web browser.
Note: The phone's http server port will automatically close after idle time of 30
minutes.
2.
Factory Reset
a.
Move to Maintenance - Re
set to Defaults screen.
b.
Click [ Reset to Factory Defaults ]
c.
Please wait.
The Base unit will reboot automatically
Apr 23, 2014 | Panasonic KX-T7636BK Digital Telephone...
Nokia 9500 network signal is not working
If the 9500 cannot communicate via WLAN but is getting a connection - do the following:
1 - set up a new Internet Access Point in control panel
2 - use the SSID (WLAN Name) to identify the network
3 - set 'Automatic IP address' to NO (Advanced Settings)
4 - give the device an IP address from the range being used on that network
5 - set 'Automatic DNS' to NO
6 - enter a pair of DNS server IP addresses (from your ISP)
7 - back up the phone settings so you never have to do this again
May 29, 2012 | Nokia 9500 Communicator
My dlink dir 300 was working fine with our 2 laptops. i bought a blackberry phone and tried to set up wifi connections. blackberry phone asked me to enter some nos. for the router. so i did. then our...
1. Restart the router by plugging it off and back on
Try to connect again
If that does not work,
go to the router's configuration page
Make sure you have DHCP enabled to assign ip addresses
Also on the devices, check to have Wi-fi turned on, and iP address to be configured automatically.
Please check and provide feedback
Regards,
Katharsys
Mar 07, 2011 | D-Link DIR-300 Wireless Router
I go to the internet on my phone i write google.com and it says (connection failed) i dont know why please help me
Check the Settings for Internet from your phone's Menu.
You did not provide a make or model phone you have, so I cannot tellyou specifically, but the phone needs to be configured to your Internet account.
First, you need an Internet account for your phone. Are you paying for Internet access to your cell company? Its not free, it costs extra on top of your voice line charge.
Have you installed the IP adress for your Internet account into your phone?
Your IP adress must be correct, most phones will auto- recieve them, but you must tell it to do so
Once again, without your make and model, I cannot give you exact menu choices, but look under Settings, then look for Internet settings, then look for IP adress info, and choose the Auto-fill feature.
Your ISP might have you give a password once you've connected. Most carriers use the 10 digit cell number as default password. Some use all zeros, some none at all.
In any case, if you have ever set up an Internet account on a home computer, then you've seen the procedure. Your cellphone Internet Setup isn't much different.
To summarize:
You do need an active Wireless Internet account from any ISP
You need the Gateway IP address, your phones IP address, and the subnet mask
Password, if any ( If forgotten, call your carrier)
Feb 01, 2011 | Cell Phones
Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
Ip phone - cannot find IP address
the phone and the computer can not be the same IP Address will not work..
Jan 26, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
Hi In spain we have an apartment which has a wifi system in the golf clubhouse. It works fine with my PC laptop but not with an apple mac laptop. Is there any reason?
Hi and welcome to FixYa,
Initially, pls determine the IP address of the Windows laptop. Pls include Subnet Mask, Default Gateway and DNS. Power off the Windows laptop. Thereafter, set the MAC to static IP address and copy the numbers from the Windows laptop to the Mac. Soon as the Mac is working, power on the Windows laptop. If ther wil be an instance that Windows displays that the IP/Network address is already in use. power down the Windows laptop. Modify the Mac by increasing the last digit of the static IP addres by at least 1. Try again.
This is of course assuming that the WiFi of the Mac is working and there are no security WEP/WPA being used on the WiFi router.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Computers & Internet
Sph200d not getting ip address from router
I had the same problem. I set up a static address instead and it works very well. I just copied the details form my laptop, diabled the laptop and set up the phone with the same details as I had on my laptop. Once I start the laptop again, it will get another address. --Jonas
Jul 23, 2008 | NetGear SPH200D IP Wireless Phone
Linksys Wireless-G WRT54GL Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
