Question about Philips 190P6EB 19" LCD Monitor
Philips 190S monitor - Urgent!
I've a Philips 190S lcd monitor that's got issues, and I need it fixed for a theatre show that opens in a week. So all help is greatly appreciated!
I use it with a 17" Macbook Pro.
The monitor turns on fine - I can see the shared wallpaper on the display. After a few seconds, the display goes black (but green power light is still on).
If I turn it off, then on again, the same thing happens - Display for a few seconds, then goes black.
I've tried - In the few seconds it allows - Changing refresh rate and screen resolution.
I've opened her up and there are no burnt out capacitors - Or anything else for that matter that's obviously wrong.
Any help would be greatly appreciated!
Thank you in advance
    Scholar:
  • 34 Answers
The lcd has three parts the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flatheaded, practice using two pennies stuck together()with your finger after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new
one do go burst! you have to laugh really, what next , a new on/off
button, as you work though the whole inverter !
mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.
Posted on Feb 08, 2010
  • 11,361 Answers
The capacitors may look fine without any sign of bulging top or bottom seal bulging but they can have high ESR (Equivalent Series Resistance), you cap meter to verify that ESR. The problem can be one or maore lamps are bad, you will need a set of spare lamps to find out if it is the inverter is bad or the lamps are bad. I have spare lamps for testing and cap tester with ESR function. The only thing you can do without all those tools is to check and see if the 12vdc (for the inverter cirsuits) goes away when the screen goes black. You can look here at example of failed monitors, test lamps, bad lamps, tools, etc. here: http://s807.photobucket.com/home/budm/allalbums
Notes: the inverter circuits will go into shut down mode if it is drawing too much current or if the lamps fail to stay conducting after the fire up sequence during start up if the lamps.
Posted on Jan 30, 2010
How do I tilt my Samsung 190s monitor?
If you mean tilt back/forward, grab the screen with your hands from both sides and tilt the top towards you are away from you.
If you mean rotate to get vertical instead of horizontal orientation, you should look at the back of your monitor to see if it even allows that movement.
Try downloading the User Manual if you don't have one:
http%3A%2F%2Fmypdfmanuals.com%2Fuser-manual%2CSAMSUNG%2CSYNCMASTER%2B190S%2C771044.pdf&ei=fwdgUvSCBoPiyAG_u4HgCg&usg=AFQjCNFYTlCuYjoHd4j7epiG7VRCpSalsw&sig2=iplcvOt8JdNoQqHqbG1g5A
Oct 17, 2013 | Samsung 190S (Silver) 19 in. Flat Panel...
No display on 190S monitor. It's 3 or 4 years old and has worked great until today. The green power light is on, but no display. I tried rebooting the PC and turning the monitor off and back on. The...
It can be the backlight inverter circuits went out, open it up and look for bad caps with bulging tops first, then look for 12~18vdc feeding the inverter circuits. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | Samsung 190S (Silver) 19 in. Flat Panel...
I have a monitor philips 190S and the osd main control is locked. how i can unlock?
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
Dec 06, 2009 | Philips 190S7FB 19 inch LCD Monitor
Philips 190s turns itself on/off
Mine is a 190s Monitor and not a TV with any kind of remote unit controlling it. I had this issue about a year ago and it sorted it's self after a week or so left turned off. This makes me wonder if it has to do with heat and humidity affecting the micro switches located behind the push button controls on the removable screen surround.
Dec 01, 2009 | Philips 190S8FS 19 inch LCD Monitor
Monitor flicks on but does not stay on
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 28, 2009 | Philips 190S5CB (Black) 19 in. Flat Panel...
Theft Mode Enabled on Philips 190s9fb/27 monitor
The display may have been tasted on another pc from the store/company.. This message is activated after a while (or immediately) when connected to a new box. So far I have had this issue on a Philips 22" wide and HP.. both fixed after installing the little software that came with the displays. HP usually has a THEFT option within that installer. The philips one fixed itself upon restart.
Mar 16, 2009 | Philips 190S9FB Monitor
Can u help me?
this is system power scheme, to save power when the machine doesn't detect any action on the keyboard of the mouse for a preset time frame.
go to control panel>power options and change the hard drive shunt down time, and the monitor shunt down time to what ever you like.
Oct 23, 2008 | Philips 190B6CB/27 19" LCD
Help with my 190S monitor
The OSD button has gone faulty.
The button will need to be replaced , or it might just need spraying with a contact cleaner like RP-7 or WD40.
Both solutions will require the removal of the front cover to access the button.
Jun 06, 2008 | Philips 190B6CB/27 19" LCD
Computers & Internet Logo
1,450 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
