I think you need to check the color settings on your new LG TV and ensure all cables are securely connected. If the issue persists, you don't have further options except to contact LG support for assistance.
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
Turn on your Wii console and set your television to the input select being used.
If you are seeing the image from the Wii in black and white, try the following to get the image in color:
Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
An on screen menu option. This is often accessed by using the "Menu" button on the remote.
A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
just check the vcr system in your tv try to change it between pal ,secam,ntsc or try to m ark it as auto if your tv support auto system picture and that happen because maybe your dvd and wii games vga card support one of these vcr color system
Well i think that the rf switch might be causing the problem snowy tv scrren no colour or fuzzy tv screen then its the rf switch thats causing this type of a problem then. If using a digital tv you need to plug it into a VCR or a DVD player for it to work then.
no your wii is in pal (UK EDITION) while your tv is NTSC( USA EDITION) so not compactible. So try seeing if tv has setting of switchin to pal if not sorry this means you can only by and play uk games if you got the wii in the usa its the opposite for you.
switch the colors around till it works. You are getting a video signal, but the colors are back wards. Are you hooking it up composite, component, or HDMI?
to hook up the wii, plug the censor bar into the back of the wii and the a/v jacks into the tv/vcr/dvd player(line the colors right(red with red, white with white and yellow with yellow))and connect the opposite end into the wii. Then take the power box(big gray box with outlet cord attached) and plug it into the back of the wii and wall, turn on and play some great games
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
the cable colors have to match the tv ones if you have different colors on cables then look for the label on the cables saying video or audio (red)=audio (white)=other audio (yellow)=video EXAMPLE if the cable colors are different than the tv then if the label on the cables say video and the color is blue etc. then you have to put it on the yellow putin on the tv no matter the color. If it dosent work then try holding the cables in many angles try pulling them or anything unlit they work get something to hold them up if that dosent work then i think you should buy new cables. [email protected] for more questions
