Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Sanyo VPC-E760 Lens not closing
By scrcfl on Feb 17, 2008
My camera lens will not close, and is unable to take pics. Screen says "Lens Error 27" then "Lens Error 17"
Same Problem
Dec 26, 2008
-   HRELP-   Guest
Dec 09, 2008
-   My camera is almost brand new and the lens won't close. It reads lens error 27. It comes on for a second then shuts off.-   scstephaniec
Nov 16, 2008
-   I have erroe lens 27 on my sanyo digital camera moddel vpc-e870
it also will say erroe lens 11. Please help me. if i coudl atleast know what is wronge to try to fix it. I have taken my whole camera apart and have no clue what to do now that i am on the inside. Thank you -   crazychike10
Aug 06, 2008
-   my camera will not close & says lens error: 27, when i look at pictures it's the only thing that shows & then it says lens error: 11 my camera is brand new & i just opend it.
-   nadiaaaliyah
Aug 02, 2008
-   My Lens Doesnt Want to Come Out. It Only Comes Out If I Turn It Own Andd Pull It Out. And When I Turn It Off The Lens Only Goes In Half Way. How Can I Fix It.-   ahhchewpati
Best Solution
posted on Mar 29, 2008
Helpful)
Racheltea
Rank: Apprentice
Rating: 91%, 9 votes
ugh! I have the exact same problem! It said lens error, so I turned it off. Now it will not come back on and the lens will not close, it is stuck out. This is so frustrating, any ideas how to fix it?
Was this helpful?
Yes
No
Solution #2
posted on May 12, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
to fix this problem is quite a job. I took mine apart to find what had happened and worked out why it wouldnt work. It is very difficult unless you have taken things apart before. Basically there is a large ring gear that turns to focus the lens. inside this ring there is 3x pairs of vertical grooves a thicker set of grooves which is to locate the ring over lugs and a thinner set of grooves which is used to drive the lens out. What happens is the shock of being dropped jumps the grooves so the lens pins go into the thicker track which then jams. Even when i sorted the lens it wont work as i think it burnt out something. although it does drive out correctly now.
Solution #3
posted on Aug 28, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i fixed this problem myself. i dropped it on the lense so the lens got jammed in... what you have to do is manually put your lense out... i had to toy with it and really give it a good pull.
Solution #4
posted on Feb 29, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
take your camera to a repair shoppe. or, email the company or call them. the lens isnt closing is a sign that it was knocked out of alignment. did u drop it or something? call the company and if it was a careless mistake on their part, they'll repair your camera for free even if the warranty is expired. if it's your mistake, then call a repair shoppe. they will usually charge 30 to 50% of what you paid for your camera.
hope this helps.
Solution #5
posted on Jul 05, 2009
Helpful)
qweedo123
Rank: Apprentice
Rating: 92%, 3 votes
THis is really easy to fix. just pull the lense out so it is alligned. it might seem like your breaking the lens but its just jammed.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #6
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
same with me. this sucks
Solution #7
posted on Sep 16, 2009
Not Rated)
all-guru
Rank: Guru
Rating: 86%, 234 votes
Well lens errors are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism.
Check the below link to do a try to correct it -
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor. This part is replaceable at an authorized Sanyo Service Center. Aprox repair cost is $120.
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
best for close up pictures for ebay
Answer
sony digital camera charger
Answer
my daughters i531 has stopped taking pics. it does everything including focus brackets turn green... (More)
Answer
my jazz dv169 6.6 camcorder software want download with vista where can i find a driver to download... (More)
Answer
missing usb cable. Is compsny out of business?
18 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Aug 01, 2008
When I turn the camero on and go to take a picture it reads error lens 27, Why?
Comment by Guest, posted on Jun 13, 2008
My lens wont close either and I cant get the camera to stay on. It turns on for a brief second and then shuts right back off. What is the problem and can it be repaired.
Comment by JAMIACAN BOI, posted on Jun 06, 2008
MY SANYO VCP-S650 LENS IS NOT OPENING OR CLOSEING AND IT SAYS LENS ERROR 1302
Comment by lynjones, posted on Jun 02, 2008
when camera is off the lens retract in but it is open but when i turn the camera on it extend but the lens closed. what should i do?
Comment by TamaraTES, posted on May 11, 2008
My battery died right before I was about to turn it off and the lens was still out. Now that the battery is recharged and back in the camera, the lens still won't go in and the error message 'lens error 12' 'lens error 28' and 'lens error 22' appear simutanously. I just recieved this camera yesterday so I'm positive the warrenty is still good. How do I fix this problem?
Comment by bb13, posted on Apr 27, 2008
My camera fell and now my ens will not close. I just got November '07. Can I come to BestBuy and will you fix it???
Comment by camerawoes, posted on Apr 01, 2008
MY lense will not close either same model-- and just got it Dec 24th!!
Comment by lillela, posted on Mar 27, 2008
my camera wont take any pictures and it says lens error 27 and the atuo focus doest want to come out
Comment by Shadow123, posted on Mar 23, 2008
I received my camera as a gift for Christmas and the lens will not close and it keeps reading lens error: 21 It also will not let me take pictures and the camera was not dropped.
Comment by portie, posted on Mar 11, 2008
when i turn my camera on it will say lens error and immmendently turn off
Comment by biggie1, posted on Mar 02, 2008
camera is saying lens error 41?
Comment by KSTEEP, posted on Mar 02, 2008
YES MY CAMERA'S LENS WILL NOT CLOSE AND IT SAY'S "LENS ERROR" AND I CAN NOT TAKE PIC'S
Comment by madmomof2, posted on Mar 01, 2008
I have had the camera for less than a month and mine is doing the same thing. Playback is fine but anything else... Lens Error
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Digital Cameras:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
