Question about JVC AV-36950 TV
JVC tv shut off and won't come back on
I have a JVC 36" tv (model #AV36950), 9 yrs old. While watching the set today, it suddenly made a "popping" sound and shut off, then kept trying to power itself up. The power indicator light kept coming on and off as if someone were pressing the power button, but no picture. I unplugged it and it stopped. When plugged back in it did the same thing. No warning or problems of this sort before. Is this a power pack thing and is it something I can replace or reset the unit? Thanks for your help.
jeff
  • miataman1 Feb 22, 2008
    Picked up the set from the repair shop today. Yes, it was a power supply problem. Don't know exactly what was done, but it involved replacing a capacitor, a diode and repairing the pwr supply. Cost was $129 total and set works like a charm again. Hopefully will buy me several more months until I'm ready to spring for the LCD set. thanks for the help.
    jeff
Check the flyback it has a leak hv
Posted on Feb 22, 2008
    Genius:
  • 1,665 Answers
It is a power supply problem. As your set is nine years old all the electrolytic capacitors at the power supply area may be out of range. If you are not familiar with electronic repairs it is bettter to take to service center to check and decide according the cost you will asked.
Posted on Feb 17, 2008
Lt 50a330 jvc
I was watching my tv model LT-50a330 JVC and it made two popping noises and the screen went balck but the green power light stayed on. I unplugged it and could smell something bad like a short. I havnt tried to turn it back on, does this mean I need a new tv, it's not even two yrs old.
Aug 02, 2013 | Hitachi L42A403 42 in. LCD HDTV
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
I am watching my 14 days old JVC 21"TV but
Hello
Your TVs power supply regulator section has got some trouble with it, that is why power indicator doesn't light up. You have purchased it only fourteen days back, surely there will be warranty for it. Do not open the TV. The company will give no concession if the set is opened. Send it to the authorised service center and get it repaired. Some power supply faults may fatal, and may have to spend more. Since your TV is a new model, spare part availability in the open market may be difficult. Send it to them and let them do the work. OK.
Nov 09, 2010 | JVC AV-A21M3U 21" TV
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Help!! NO PICTURE/SOUND
The 'pop' may have been an arc of electricity from the flyback coil. The flyback is the device that produces very HIGH VOLTAGES --that can kill so be careful--. It may have just goten old and the material around the flyback broke down and allowed the electricity to arc to a near by source to ground. it happens when CRT sets get old. Typically I expect 7-10 years of a consumer grade CRT. Other then that any fix for it would have to be performed by a trained technician because voltages can linger in the 'caps' and even the 'tube' itself for years, I once got 'bit' by a set that was left un-plugged for 5 years.
Aug 15, 2008 | Sony KV-36FS100 36" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
F36650
Bad flyback transformer = 257805 or Asti 2078..........T.
Please rate this solution.................
Nov 05, 2007 | RCA F36650 36" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
JVC AV-36950 TV Logo
126 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
