Question about Frigidaire FLGB8200DS Top Load Stacked Washer / Dryer
Water drips while off cycle in FLSE72GCSB
Is this the fill vavle that needs to be replaced?
Thanks.
  • Gary Davd
    Gary Davd May 11, 2010
    sounds like it to me is the water going into the tub??
Correct, it drips with one drop per 2 seconds rate into the washer tub.
Posted on Feb 18, 2008
Fisher and paykel GW711
Replace the water inlet valve. That will fix the problem. No need to replace anything else.
Mar 06, 2018 | Fisher and Paykel GWL11 Top Load Washer
Cold water does not come into the machine and when washing the water keeps coming into the machine and the washer overflowed
bad fill vavle..it stuck open pull plug than replace the fill vavle....if you need help replacing vavle repost with model number ..good luck
Sep 10, 2011 | Whirlpool Washing Machines
I have a KitchenAid model KUDI01ILBT2. It was working fine until recently...The lights work fine, but when I push the start button it's delayed before it actually kicks on, and then it will...
sounds like you have a bad or clogged fill vavle,,you have water running to unit but not in unit,,,its still trying to dry dishes as if they wash...most dishwasher are hard wired to breaker and or not grounded,,,but only if you can shut of power pull dishwasher out remove water connection,,see if any **** is blocking vavle use flash lite if present...if so replace it..good luck you can not clean a dishwaser vavle..
Sep 03, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Washing machine wont fill with water, just hums. Spin works fine, just wont fill with water.
The humming noise is caused by the water valve solenoids trying to open. You will need to remove the hoses from the back of the machine and see if there is any calcium or water deposit on the screens in the water vavles. If there is try cleaning it out and testing, if there is none, the water fill vavle will need to be replaced, you can order parts for it at, Reliable Parts by using your model number. Valve should cost around $45. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 19, 2010 | Whirlpool Washing Machines
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Washer does nothing
ok we need to check a couple of things...take the fill hose off ,,,now put unit in a cycle and make it call for water...is the inlet vavle humming or vibrating....will your there look in vavle and see if your inlet vavle screens are clogged...does the unit have water in it,,if so it wont fill with water in it...keep me posted onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
The washer is very slow to fill up with water.
cut the water off to the fill hoses,,than remove fill hose and clean water inlet vavle screens with tooth brush..onthejob
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Frigidaire FLGB8200DS Top Load Stacked Washer / Dryer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
