Question about Sony Playstation 3 (PS3) Console
Ps3 bluetooth pairing problems - Sony Playstation 3 (PS3) Console
    New Friend:
  • 65 Answers
Dont worry
and u can easily resolve your problem
Click Here to download the repair guide
dont waste money like $80.or more to repair shop........... with out knowing much you can repair your ps3 with the help of this guide .........
Posted on Oct 29, 2010
    New Friend:
The pairing bluetooth works with only of ps3 capable devices...
Posted on Jan 30, 2010
2 Suggested Answers
SOURCE:
vanherringto
  • 1738 Answers
SOURCE: Bluetooth headset is paired, but will not connect
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.....
Posted on Feb 07, 2010
How do i program my ps3 bluetooth headset?
You can pair the headset in two ways:
  • Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
  • Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
Jul 22, 2014 | Subsonic PS3 Bluetooth Headset Camo
How do i connect this headset
Pairing the Headset
Pairing is a process of associating Bluetooth devices with each other.
It will establish a permanent security link between the devices and
enable quick access to the services provided without the need to reenter
Pass Keys. You will only need to pair your PS3 and the Headset
once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Mar 13, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How to use bluetooth
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
Recently when i try to connect the bluetooth to my ps3 it says that a connection could not be established.Howq do i fix this?
If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Aug 18, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
My Bluetooth V2.0 with not pair or scan intp my ps3
PS3 supports Bluetooth V2.0, in fact the Playstation branded headset is V2.1. All versions of Bluetooth are backwards compatible. Are you sure that the headset is going into proper pairing mode?
See these tips:
Pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
Pairing to PS3:
http://www.fixya.com/support/r5009279-pairing_headset_playstation_3_ps3
May 06, 2010 | Motorola Mobility Bluetooth Hands Free...
My ps3 bluetooth headset wont pair with my ps3
go into accessory settings and connect the bluetooth device via USB so the drivers can be installed to your PS3. This is how i connected mine.
Feb 22, 2010 | Ubi Soft Entertainment Tom Clancy''s...
PS3 bluetooth headset won't work
hello,
ive had the exact same problem
make sure that the blue tooth is in "pairing mode" when the system is scanning.
reference to the bluetooth manual to put the device in pairing mode.
I hope i have helped and I hope it works
Jan 14, 2010 | Sony Playstation 3 (PS3) Console
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
Hope this helped.
Nov 18, 2009 | Mad Catz Bluetooth Headset for PS3
I want to connect it to my ps3 but its not reading it
Pairing bluetooth devices isn't tricky its just a bit finicky. 1. Go to Settings tab in the PS3 menu. 2.Scroll down and select "Accessory Settings" 4.Scroll down and select "manage bluetooth devices" 5. Select "Register New device" The PS3 will now go into a pairing mode and search for any bluetooth devices. 6. At this point follow the manufacturers pairing instructions for you bluetooth device.
I managed to pair my X3 Micro headset to the PS3.  I had to get on line to find the devices code because I had forgotten it, but after entering the right code the PS3 hooked it up and I have been insulting those who kill me online ever since :P
May 05, 2009 | Video Game Consoles & Games
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
221 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
