JVC AV-27870 TV Image Problem
I have a JVC Color television, model AV-27870. Recently the TV image has degraded to a single horizontal thin bar in the middle of the screen. When the problem first started, the image would degrade and colapse to the horizontal thin bar after about 30 minutes of use. The problem now appears immediately when the set is turned on. I have the same problem with the image when using the VCR. The audio works fine. Can you help identify the problem and possible repair?
    Novelist:
    Champion:
  • 211 Answers
Hi Bruce,
Sounds like you have shorted or open Vertical Filter Capacitors. ( you may also have a bad vertical drive chip now since you've waited to replace the capacitors). You'll need to replace the bad capacitor/s and if the problem doesn't go away, replace the chip also. And as always, check for any cold solder joints ( bad lead connections to the printed circuit board ) as you replace the bad components.
I Hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Posted on Feb 18, 2008
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
JVC AV 60D501 H hold ?
What do you mean jumping, or does the picture look like it is in 3-D?
Aug 10, 2007 | JVC AV-60D501 60" Rear Projection...
JVC AV-56WP74 Colors quit working or went out of balance.
Guns or CRT are probably ok. Your TV needs a convergence IC STK392-120 replacement. Lamp are used on LCD and DLP rear projection TV's. Color wheel are for DLP's. :)
Dec 26, 2009 | JVC Televison & Video
Curved lines on screen double image poor color
Ur convergence it dead,U know how to solders?Buy a convergence kit,use what in that kit,ur tv should be back to normal.Try this website.Tv repair World.com for the convergence kit.
Oct 20, 2009 | JVC AV-56WP74 56" Rear Projection...
Horizontal lines across the top of the screen
Hi and welcome to FixYa,
Your described problem is indicative of a failing or near end of life capacitor in the vertical section. The capacitor (often called pump capacitor) would be in the neighborhood of 100uF 35V and physically near the vertical IC. In some JVC models, the vertical IC would be an LA7838 or LA78041 usually a single inline package on a heat sink.
Cost wise, the capacitor is relatively cheap a dollar or less. What would be more challenging is getting access underneath the PCB to de-solder and solder in the replacement.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 14, 2009 | JVC AV-27530 27" TV
No Color image - B&W image is distorted
it could actually be the cable box itself or there could be corossion on the cable connection outside
Dec 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv display the view as three images
You need to replace the convergence ICs they are both stk392-110 you can get replacement at the following link with free instructions, they also have the kit which includes both ICs and all new resistors for your model .
http://servicemanuals.vstore.ca/
Aug 23, 2008 | JVC AV-56WP74 56" Rear Projection...
Struggling with an intermittent green (all over screen)
Do you have a color bar generator?
Connect it to the composite input 1.
Go in the customer menu select the color adjustment and turn it all the way down and tell me what you see in the back ground image from the color bars.
Mar 26, 2008 | JVC AV-48WP30 48" Rear Projection...
JCV HD Convergence Problem.
Replace both convergence IC's......Please confirm Model #
off back of TV and I will help you step-by-step....Requires
above-average soldering skill......................T.
Nov 18, 2007 | JVC AV-48WP74 48" Rear Projection...
Image doubled when using 480p
No it is only 480i with component cable support.
Jul 27, 2007 | JVC AV27WF36 TV
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
