Question about Whirlpool RS675 Electric Kitchen Range
Says it is preheating then says it is hot, but it is not....
If you turn on the over to bake or broil, it does not get hot. The digital control says it is preheating and it is not. I never gets hot... I am a do it your self and want to get it fixed... Is it the elements? What can it be? Need to get this range going....
  • 770 Answers
DO you have a meter?? Elements>....Well not really if both the elements are not getting hot it sounds like the relay in the ctrl board or a wiring issue maybe missing a leg of power first off check incoming power at the terminal block if ok 220vac-230vac then remove the back top section set it into bake and with the back end of a screwdriver tap the Black boxes these are the relays on the ctrol board.. (Note: they click when you turn them on) see if the elements come on if not unplug remove the back lower section get your meter and check for 220vac at the bake element. after you do that let me know also post your complete model number off of the unit
Posted on Feb 17, 2008
2 Suggested Answers
  • 56 Answers
SOURCE: oven does not get hot enough to bake
Probably a failure to get 240 volts to those elements.
If burners work, then it's probably an oven CONTROL(S)l failure. Test them if you know how. Very difficult to find parts for a stove that old.
Posted on Sep 19, 2009
Testimonial: "very helpful as all 4 burners work but oven does not get hot enough to bake. As suggested I will search for new oven temp control switch. Thank you "
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
I have a whirlpool range. During preheating the
sounds like you may have a bad bake element. try to see if the unit will get hot when set to broil. if it does then try the bake again. if you get no red hot heat from the bake element then you may need to replace it.
when an element is working properly it will heat to a red hot glow.
Jan 12, 2010 | Ovens
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven not heating properly
Hello. You have done an excellent job of explaining your problem. Read over the info. below as it sounds like your top element is not working.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • May 26, 2009 | Kitchen Ranges
    Kenmore oven - will not heat on bake / will heat on broil
    its your temp sensor. replace it and it should fix ur prob
    F2=overheat
    is your bottom element connected?
    Mar 23, 2009 | Kenmore Ovens
    Thermador double oven / Bake wont work /FC code flashed once
    I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
    Aug 30, 2008 | Thermador SC272T Electric Double Oven
    Maytag oven not getting hot enough
    When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
    Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
    Whirlpool RS675 Electric Kitchen Range Logo
    87 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
