Question about Brother LS-1217 Mechanical Sewing Machine
Same problem brother Ls 1217 thread will not catch
Tried every thing on inside is it the timing? and how to fix please
  • Anonymous Feb 18, 2008
    WONT PICK UP THE TREAD FROM THE BOBIN
I have this same problem. The bargainBox solution may not be too helpful. This diagram is not similar to my model. I question the accuracy of the information. I also believe it is a timing issue but this drawing will not help. I am still trying to determine which adjustment will correct problem. Removing the plastic case is easy and involves 7 screws. This reveals a sturdy steel frame which is easy to get at any adjustment. Which adjustment? Good question but oil all you want this has not cured my problem.
Posted on Apr 12, 2008
  • Brother Master
  • 1,388 Answers
Whether the machine is front or top loading, the relationship between the needle and the hook is the key to timing.
Take a look at this and see if you can adapt it to your machine, the theory is the same.....the relative position of the needle rising 2mm with the hook just so.......the method of disengaging the main horizintal shaft and hook gear may be slightly different to this, so see how you get on.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 19, 2008
Please what do i have to do to fix my machine?
Take your machine in for service. As long as there are threads stuck in the machine, it will never perform satisfactorily.
Feb 03, 2016 | PfaFF Sewing Machines
What is wrong with my dog?
Sounds like she is not getting enough exercise, you need to establish a routine that stimulates and wears her out so when she goes inside it is sleepy time. I take mine to the dog park every day for an hour and play frisbee until they are done, this stopped all destructive behavior!
Nov 15, 2013 | Sewing Machines
Timing is off doesnt grasp upper thread nothing happens
It is amazing how much those stores know. I suppose that could be a common thing among that particular machine.
Whatever you do don\'t buy a "WHITE" machine as they work for about 2 hours then they die. I had to keep taking it back and forth 45 miles each way for over 1 month and the person whom owned a shop couldn\'t fix it. Of course he said it was fixed and when I stepped on the gas nope same thing happened.
I also won\'t ever buy any new singer machines. They are bad...now if you can get a hold of an older one that is medal inside instead of plastic parts it would pay to keep it running.
I have sewn for over 42 yrs. I have gone threw a lot of different machines trying them out. I own about 6 machines now not including my embroidery/sewing machine or serger. I always have one or more working. I was tired of having it break down at Christmas time.
I even loaned out one to my 18 yr. I took her 20 yr old Janome (all metal inside) machine into the shop.
Oh yes, youtube has videos on everything!
Nov 09, 2013 | Brother Disney ULT-2002D
Why won't the bobbin thread pick up?
have you tried changing the needle? if it's a new needle is it inserted correctly---flat side to the back of the machine---needle push up in inside the needle holder
have you tried cleaning under the needle plate & in the bobbin area for lint or loose threads?
have you checked the bobbin to make sure it's not warped
have you checked the bobbin is inserted correctly?
if you've already tried these things then the last thing that possible is the machine is out of time & needs to be serviced by a repair shop that have the correct tool to time it
Aug 29, 2011 | Brother XL-2600
I owen a Creative Touch Fashion Machine Model 1030. I tried to fill the bobbin and the thread is filling under the bobbin instead of inside the bobbin. Had it fix in late 2009 and it came back with this...
I've had that problem before, I wrap several loops on the bobbin it's self & as I start to wind I make sure the thread from the spool is pulled tight from the spool to the bobbin,,& that usually takes care of the problem
Aug 01, 2011 | Singer Sewing Machines
My tread keeeps breaking or tangleing. i have tried adjusting the tenion and rethreading the entire thing. sometimes the needle hits the bottom, i dont know how to fix this. was working fine, then it just...
You may have knocked the machine out of time if the needle is hitting somewhere, email me and I will attach timing instructions, drivewithken@blueyonder.co.uk
Aug 11, 2010 | Kenmore 12912
Tension problems with top thread husqvarna emerald 203 sewing machine how do i fix
check your owner's manual there should be a page on upper & lower thread tension
Jul 29, 2010 | Husqvarna Designer I
How can you fix the under threading of a sewing
Check the ovious things first make sure you needle isnt broken... then make sure there isnt any thread twisted inside your bobin housing. make sure bobin is inserted correctly if those things dont help it could be an issue of timing in your machine... I work as an embroidery operator in a factory setting and those things usually help..
Apr 08, 2010 | Singer 3116 Simple
Brother LS-1217 Mechanical Sewing Machine Logo
198 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
