Question about Samsung SGH-d807 Cellular Phone
Broken slider The 2 long pins on the inside of the phone have fallen out. The phone still works, but the front and back are connected only by the ribbon. Can't seem to get the pins back in correctly. Any suggestions? Thanks.
    Brigadier General:
  • 7,752 Answers
Take it to a mobile technician and have them replace it back for you
Posted on Feb 17, 2008
Replaced the broken glass front of my iphone 3GS. Everything looked fine, but the slider on the screen does not work... Did the replacement protocol all over again, but nope no slider. Any...
On touch screen phones like the iphone and N97, when replacing the screen there is a small ribbon attched to the back of the screen that connects to the main circuit board.This ribbon allows your phone to recognize you touching the screen and makes the screen work. Take the front cover back off and check that the connector is clean and dust free (on the new screen and on the phone) reconnect the ribbon and push down gently until its securely in place and re-attach the screen to your handset.
This should solve your problem and hope it helps please rate thanks
Mar 19, 2011 | Cell Phones
Slider part keypad not working properly, only number keypads are working
Possible that the flexible membrane strip of the connection to the slider keypad is broken off there by cutting off the connection.
These membrane strip wires must be procured to be installed back into the main board and connected to the slider pad.
Attempt only if you are experienced to do these delicate jobs.
Oct 23, 2010 | Cell Phones
An apartment complex where I do maintenance has intermatic outdoor timer, a very simple mechanical timer . It keeps good time tabs are set for off and on and yet sometimes the lights are on past the off...
Timer pins make physical contact with a metal lever that has a bit of grease. When the metal lever is pushed far enough by the pin it clicks into 'on' or 'off' position. The lever moves a slider on back of timer. The slider pushes and pulls the brass-copper contacts located on back of timer.
The metal lever is connected to manual override. So the manual override changes position with each on-off function.
1) When you click the manual override back and forth, is it loose? Or does it snap crisp and clean with no play? This would tell the general condition of the lever mechanism.
2) It seems the pins are a softer metal than the metal lever ... but if the metal lever is worn, the pins might slip past without turning off lights. You can watch the turn-off sequence and see what happens.
3) The contacts on back of timer are pushed together and pulled apart by the slider, so burned points would not cause the lights to stay on ... unless the stop that holds the stationary contact is somehow broken. You would have to take timer out of box and click it back and forth to see what the contacts are doing.
http://waterheatertimer.org/images/WH-lever-005-500.jpg
http://waterheatertimer.org/images/Back-of-WH40-2b-500.jpg
Sep 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
The inside of my front rotor has been grinded down really bad. It look like the top of the wheel was tilted to the inside and just grinded everything, the caliper, in inside brake, but the outside pad was...
sounds like 1 of 2 things
1 bad wheel bearing
2 bad caliper sliders likely the caliper sliders are seized and will require some work remember to use antiseize when re assembling caliper especialy on sliders and bolts also remember to tighten the wheel nuts in a star patern not a circular patern as this will allow the wheel to mount the drive hub properly
Jan 22, 2010 | 1986 Toyota Camry
Slider sticks
had this happen on my samsung impression press together the front and back portion of the phone to see if the case became misaligned. You should have 8 corners to ensure are snug. If that does not work you might have a broken spring.
Jan 02, 2010 | Samsung Propel A767 Cell Phone
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
Papaer feeder not working
Most times on this machine I find toys, stick pins, nails, jewelry, fallen in the back where the paper goes. I use a flashlight and small mirror to see inside and bend a paper clip to remove what has fallen in.
Aug 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Broken USB connector
it depends if the port has come off with out damaging the board if its damaged the board its more harder to replace the port. sometimes you are luck and its just broken the slider as its tin base. and it can rip, but you cannot tell until its been opened and looked at.
Jul 03, 2017 | Logitech Harmony 676 LCD Remote Control
Slider Problem
just change the strip i mean the belt inside it will be ok
Dec 17, 2008 | Samsung SGH-i450 Cellular Phone
Slide broken
yes it can be fix, take it to a mobile reapir shop or a professional mobile technician and have them put the slider back on the base of the phone.
Feb 08, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Samsung SGH-d807 Cellular Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
