Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
VUD 141 We just purchased a used Viking dishwasher and its great except it did not drain completely when the load was done. What do we need to do?
  • Anonymous Jun 11, 2008
    Yes... water does not pump out.
  • 205 Answers
Vking dishwashers are made by Asko, which are know to be poor drainers. If your drain line is connected to an air-gap disconnect it and run the drain line direct to the garbage disposal. Asko pumps do not like to drain very far. As well, make sure that the filter screen is clean in the bottom of the tub.
Posted on Jul 21, 2008
Just click the handle to start the cycle and let drain.  Then just before it starts, turn it off.
Posted on Jun 25, 2008
Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
Aug 10, 2012 | Viking DFUD142 Built-in Dishwasher
Dishwasher doesn't drain completely and then turns itself off. Dishes are not clean.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
Sep 12, 2011 | Viking DFUD042 Built-in Dishwasher
My Viking DFUD042 is stuck in drain cycle while fresh water is entering the dishwasher through the grid on the right side. The pump is working continuously and it only stops after I turn off the power. ...
Hi, this could be a bad control board or a bad motor. It uses the same motor to wash as to drain. It just changes the direction of the motor in order to switch from drain to wash.
You'll need to run a cycle and you will need a multimeter to check which one needs to be replaced. Remove the kick panel and check the grey wire to the ground wire when it should be washing. If you have 120 volts, you need to order and replace your control board. Otherwise, if you don't have power and it's still draining, you need to order and replace the motor.
Jun 23, 2011 | Viking DFUD042 Built-in Dishwasher
My Viking Professional VUD 141 DISHWASHER will not pump water through the spray arms
I have a viking VUD140 and there is no power cord. Can someone tell me where the power supply is suppose to go.
Dec 30, 2009 | Viking 24 in. Professional Series VUD141...
Viking Dishwasher
Probable cause is either a bad fill valve, common with these, or just some debris in the fill valve inlet screen, also common. If you are handy you can take apart the fill valve and check the screen but often one needs to replace the whole valve, about an $80 part + labor. Double check your valve under the sink and make sure it is on completely.
Apr 30, 2008 | Viking 24 in. Professional Series VUD040...
Left Knob Settings
goto and search your model.they may have a manual.try also.
Jan 05, 2008 | Viking 24 in. Professional Series VUD040...
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
288 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
