Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Need help !!
Im installing my hunter 44155c to replace my old maxwell. the wire colors are white,red,orange,yellow,black,green...please help me connect these wires
  • Anonymous May 27, 2008
    Funny, the attached link tried to charge me for it...
    Guru:
  • 1,463 Answers
Have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Posted on Feb 26, 2008
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Trying to wire new stereo for my 98 taurus, but wire colors dont match up! where can i find factory stereo wiring schematics
Hello I have included a wire color code for you installation. Hope this helps you out. Please rate and good luck. Israel
Constant12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination light blue/red
Left Front + Orange/light green
Left fRont - light blue/white
Right Front + white/light green
Right Front - dark green/orange
Left Rear + gray/light blue
Left Rear - Tan/Yellow
Right Rear+ Orange/red
Right Rear - Brown/Pink
Apr 13, 2010 | Car Audio & Video
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Radio installation
1995 Isuzu Rodeo Stereo Wiring Constant 12V+ Red/White Switched 12V+ Brown/White Ground Black Illumination Green/Red Dimmer n/a Antenna Right Front Front Speakers 4" Dash Left Front (+) Blue/Yellow Left Front (-) Yellow Right Front (+) Green/White Right Front (-) Gray/White Rear Speakers 4" Side Panels Left Rear (+) White Left Rear (-) Red/White Right Rear (+) Orange Right Rear (-) Black/Orange
Dec 30, 2008 | 1995 Isuzu Rodeo
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
773 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
