Question about HP f2105 21" LCD Monitor
HP f2104 LCD black screen
The power light is blue, there are constantly black screen. If I press the VPN select button, I will get a scrren very shortly, and there is a message box showing there is no signal. But the screen is correct. According to HP's online help instructions, the signal processor should be repaired. But HP told me there is no repair for f2105. They give me a ticket number to help me to buy a new one.
  • dehno May 25, 2008
    Hello
    Thanks for the information in regards to the hp f 2105 monitor black screen problem. I replaced the back light inverter board, the screen comes on but after about 5 mins of use the screen flickers like a strobe light and is makin me nuts! Could it be a defective inverter board? what is weird also is that when I adjust the brightness down the flickering is not as intense. Please help if anyone knows what the **** is wrong with these expensive hp monitors!
My tv power light comes on,but the screen stay black,and in the back of the tv there is a red light that flashes.
Posted on Jun 12, 2011
The above fix worked perfect. Inverter was $99.99 w/ shipping. Easy to install, just follow the instructions on the site. Thanks!!!
Posted on May 19, 2008
You need a new backlight inverter board.Mine was doing the same thing.Its an easy fix and costs $89.99 for a new upgraded part,that will last much longer and is built better.If you have any questions and are'nt sure,send them an e-mail first,detailing the problem as you've done here,before buying one
http://www.lcdparts.net/DesktopInverterDetail.aspx?InverterOriginal=48.L1S04.A01MSS
www.moniserv.com
Posted on Mar 09, 2008
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
I have a hp dv6000 , it boots up with a black screen what could it be?.
It is possible you inadvertently disabled your notebook screen. There is a feature that lets you alternate between the internal screen and an external monitor/projector. This is used in presentations and docking situations.
To check - try this, in the lower LH corner of the keyboard, find the "fn" key. It is sometimes blue in color. Now locate the F4 key. You should seen a symbol on it that looks like a large oval with vertical lines on each side. Press and hold the "fn" key. While holding it down, press and release the F4 key. If you had accidentally disable the scrren, this should restore it.
If that is not the case. wait for the system to fully boot up. Take the unit out of direct lighting, but not into a dark room. Look at the screen from a slight angle. If you can just make out images on the screen that resemble what your normal display looks like, then what has happened is the the fluorescent backlight that make the LCD visible has failed. This requires a rather extensive effort to repair.
Jan 03, 2012 | HP Pavilion dv6000 Motherboard
Power button is on (blue) but no display. If you
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Lcd dislpays lights up but thats all
Check Your Input - Press your input button and try different ones to see if you should be on a different one
Jul 25, 2009 | Polaroid FLM-323B Television
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
The screen only give a light blue window
have you made any system upgrades or changes
like memory or OS
Can you get into safemode by pressing F 8 constantly while in restart
Jan 19, 2009 | Computers & Internet
My monitor is stuck in a constant color loop...
What you are seeing is a test they use at the factory. Here are the instructions to reset the monitor:
1. Press the MENU button
2. Use the + and - buttons to choose Advanced Menu
3. Press the SELECT button
4. Select Factory Reset
5. Select Yes
6. Press MENU again to remove the onscreen menu
Hope that helps :)
Dec 13, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP f2105 21" LCD Monitor Logo
332 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
