Question about Dell Dimension 3000 PC Desktop
I just bought a new motherboard and managed to swap everything....except the power switch cable
Except the original power switch cable (and LED,etc) isn't the right connector type (16-pin) on my new motherboard (biostar pm4900-m4) and the cable is too short to reach the right board connector as well.
how can i mod the connector type/length so it works with the board that i've just purchase and swapped everything over to?
cheers,
m
    Genius:
  • 3,587 Answers
Whew..that's not as simple as it looks. You'll need a pin out configuration guide, if one exists, or you'll need to make one. The power interface from front panel, is usually unique to each Dell, so its' not likely to swap over.
got backup for that Dell?
Posted on Feb 17, 2008
I just bought a new power supply for my new mid tower I hooked everything up the way it suppose to be the motherboard led , and he hard drive led ccmes on No screen
Disconnect all other connections on motherboard except the supply connection on motherboard and re fix RAM properly
Oct 31, 2016 | Computers & Internet
Dell 2400 desktop pc will not turn on. Mother board flea led light does turn on.Tested power switch and wiring okay.I did swap power supply pack from a good working 2350 Dell pc same problem any...
Try to remove all components all drives (hard drives, cd/dvd roms, floppy drives, etc), all additional cards (modem, video card, sound card etc), remove the memory. Just leave the motheboard, proc and power supply. Before disconnecting everything completely discharge power by holding down the power button while the computer is unplug from the power. It should clear the flea light on the motherboard.
Test it again with just the motherboard, processor and the power supply. If still no power then most likely it is the motherboard since you already put a known good power supply. Motherboard has higher failure rate than the processor. You can swap a known good processor if there is.
Jul 25, 2011 | Computers & Internet
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Just installed a new motherboard model MSI 790FX - GD70 and new ram and cpu to go with it. plugged everything in and check all the connections. When we turn on the computer all the fans start and all the...
check the cable connections initially
Remove the power cord from the cpu
Remove the cmos battery and reset the bios by changing the jumper which is present to reset bios in motherboard.
Place the jumper as if it was present already
Insert cmos battery and switch on the computer
Mar 04, 2010 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
DELL PowerEdge 1600sc - New motherboard no joy
Are you sure the new motherboard was of the same revision as the old one? Dell shipped 400FSB boards during the beginning of the 1600SC line and shipped 533Mhz boards during the end of the run. I would check the revision level of the motherboard to make sure it is compatible. If it's the same revision, I would start small and connect just one CPU and put the system at 512mb ram and see if that works. If this works, you can begin to add additional components as needed.
Good luck
Jun 19, 2009 | Dell PowerEdge 1600SC Server
Pin connections on the motherboard of Acer Aspire AX3200-U3600A
You'll need to know the model of your motherboard, and search for the motherboard manual in the internet if you don't have one.. in the manual search about the power pin connections and you will see where to connect those wires into the pin..TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Biostar P4M80-M7A motherboard
You're board does not use an integrated graphics card.
Monitor does not have video display. There can only be four reasons why.
1. The monitor's video cable is not connected correctly at each end (Video card & Monitor) or cable is bad.
2. The monitor’s power cord is not plugged into a good power source or cable is bad.
3. The monitor may be bad.
4. * The AGP graphics card is either not seated correctly in its AGP slot, (remove/clean copper contacts with alcohol/allow to dry & reseat snuggly), or graphic's card is bad.
Monitor’s power cord can be switched with the PC's power cord.
The video cable & monitor can be swapped by borrowing from a friend.
(Just make sure their stuff is working first).
Never open the PC case without unplugging the power cord first.
Luck!
Mike
Apr 16, 2008 | Biostar P4M800-M7A Motherboard
Dell Precision 340 Minitower Power issue
Fauza
Hi
First things first:
1) You just change the power on button for other, on Radio Shack they have it.
2) cables that came from the motherboard to the ON/OFF SW. you have to soldering with the new Power Button, thats it. very easy task! you can use any power botton to fix this.
good luck
Feb 08, 2008 | Dell Precision 360n PC Desktop
Dell Dimension 3000 PC Desktop Logo
110 people viewed this question
Alun Cox
