Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Samsung refrigerator rs2555sl / evaporator iced up
Refrigerator has dual evaporators (twin cooling technology), freshfood evaporator icing up, sensor and thermo metal appear ok, is it the main circuit board (pcb).
  • 5 more comments
  • TerryGarvey Apr 28, 2008
    I have the same problem. The back of the inside-behind the panel ices up. Is there anything I can do, otherwise I am defrosting with a hair dryer ever month or so. m Does anybody have this problem or is this something unusual?
  • mukarafu Jul 03, 2008
    I have the same problem. The back of the inside-behind the panel ices up every week. I am defrosting weekly and this is getting realy old. Has anybody had this problem resolved?
  • Anonymous Dec 28, 2008
    I also have the same problem, where the ice builds up and makes that funny noise with the fan. I've also tried defrosting it with a blowdryer only to have the same issue re-occur two weeks later.
  • jay1028 May 04, 2009
    I have had the frige evaporator icing problem since 2006 and have been unable to get it resolved. Removing about 10 screws in the frige to remove a panel covering the evaporator and using a hair dryer to melt the ice on the evaporator coils seems to be what you have to do when the frige temp indicator begins to blink. Many technicians have come out and not solved the situation. Now they don't service Samsung anymore because of the lack of support from Samsung.
    How does Samsung get away with designing such a poor refrigerator. Mine is the RS267LASH but a lot of other models exhibit the same problems over and over again.
  • captimpossbl May 08, 2009
    Samsung side by side model # RS2545SH: Evaporator iced up, defrost sensor not working, causes refrigerator side to operate @ around 56 degrees Fahrenheit. Problem fixed by local repair company for $156 + freon disposal, total $198.00. 2 months later, same problem has recurred.
    Also, the ice maker has never worked properly and it makes a periodic, strange loud cracking noise at night which wakes us up sometimes. Has anyone initiated a class action lawsuit against Samsung yet. From what I've read on-line, some attorney should be extremely happy to take this case. Good luck to all our fellow Samsung refrigerator owners out there. Oh, and their customer service is really terrible.
  • Anonymous May 12, 2009
    Ice maker defective.
  • Alastair Macleod
    Alastair Macleod May 11, 2010
    What have you done so far to prove the sensor and thermo metal?
I had the same problem .kept on defrosting every week for . months replaced the sensor assy DA32-00006B fridge has been working perfectly for the last 2 months stan
Posted on Jul 27, 2008
  • stanza 2104 Oct 27, 2008
    stanza 2104 fridge is still going strong. No problems
  • 3 Answers
If you need a new Main PCB for a Samsung Refrigerator, I have several new in boxes. Please e mail me with model # and I will see If I have one that will replace the faulty one. e-mail me @
Posted on Oct 11, 2009
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine.
Ice cannot be produced at that temperature you're going to have to find out by taking the drawer out removal of the rear wall of the freezer and see if the evaporator is freezing over or is the condensate drain opening is blocked. Your model has dual evaporators and we need to see if your evaporator in the freezer is defrosting properly or if for some reason the defrost drain is blocked causing moisture to cover the fan causing a cooling problem.
Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
I had ice over my fan in the fridge side i have a Samsung French door fridge the fan had ice all over it now it is not working
Defrost the ice with a hair dryer and clean the drain below the evaporator, then try it. Samsung dual evaporator models are well known for this flaw. Like my help? What is the model number of the fridge?
Apr 14, 2016 | Samsung Refrigerators
Samsung model#rs2577bb freezerworking good refridgerator not maintaining temperature
Not really a permanent solution for Samsung refrigerators with a evaporator inside the fresh food section. You will need to remove the shroud housing the evaporator and clean out the drain opening along with removal of any ice buildup. User Manual HERE
Here is a link to a troubleshooting page that covers your model=> HERE You need to clean and make sure the sensors at base of evaporator are clean and function properly. Also insure condensate drain below evaporator remain clear of blockages ice/gunk. Parts breakdown can be found HERE. I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 12, 2014 | Samsung RS2534 Side by Side Refrigerator
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
Oct 12, 2013 | Refrigerators
Refrigerator, freezer works but not the fridge stays at 10 c
Remove the housing that covers the evaporator inside the fresh food section and remove any ice or sludge that may be blocking the defrost drain below that evaporator. Insure no ice or water is touching the defrost sensor for that section. This is a common problem that Samsung has with it's dual evaporator refrigerators. With that drain blocked the problem will only become worse.Thanks Sea Breeze
Feb 10, 2013 | Samsung RF197ACRS 18 cu. ft. French Door...
Refrigerator not cooling
If you had ice on the coils you will need to replace the defrost thermostat. Here is the part to order.
Nov 17, 2012 | Samsung RS265TDRS Side by Side...
I have a samsung RS2555SL the fan does come on and the refrigator side is not cooling the freezer side is cooling.
It sounds like you have a iced up evap in the Fresh Food side so You need to clean all the ice near the top light and all from all the places.
Appart from this you should also get the thermistor checked and the frig fan. Doing this will fix the problem.
May 30, 2010 | Samsung Refrigerators
Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Jul 13, 2008 | Refrigerators
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
4,116 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
