My computer monitor power supply is not coming. Computer is fine. If connect the computer to another monitor it works fine. I changed the power cord no help. Can you suggest something to find the solution for this.
Thanks
Sudha
Comments:
Feb 19, 2008
- Can you explain where the fuse, resistors, transistor, cold solder are and how to check it?
Thanks
hi there, check the hardware of the monitor, do some test at the power supply., i.e. fuse, resistors, transistor, etc., have some check up for cold solder. ty
Samsung syncmaster 591s showing error as EZ?,not displaying screen,not able to access menu Settings...
(More)
Samsung syncmaster 591s showing error as EZ?,not displaying screen,not able to access menu Settings also
hello there, my problem in the monitor was, its always change in color every time i touch the...
(More)
hello there, my problem in the monitor was, its always change in color every time i touch the monitor
The color settings on my Mag Innovision flat screen monitor keep changing. This has only started...
(More)
The color settings on my Mag Innovision flat screen monitor keep changing. This has only started happening since I loaded Windows 7. Any ideas?
