Question about Sony DVP-NS530 DVD Player
Goodmans home dvd recorder
Hi I can burn dvd+r with home stuff cam recordings and it plays fine through my tv/dvd recorder fine, but when i try to use the same dvd disc on my pc with xp it does not start or show a dvd disc is in the tray. is this down to a format that it has been burnt by my home dvd recorder that my pc cant recognise !. However my pc will play normal and pirate dvd's with no prob.
  • ken0 Feb 18, 2008
    As i have no way of fianlising the disc being the goodmans dvd recorder allows me no options on that i presume your second option is the answer.....ho hum
  • 70 Answers
Make sure the DVD has been finalised. When you finalise a DVD the recorder puts all the disc content information at the start of the disc so that any device you put it into can find out what is on the disc without scanning through 4.7 Gigs of data, (which would take so long it would drive people mad everytime they put a disc into anything). Because the table has not been written the PC cannot see what is on the Disc.
Another possible answer: some makes, Orion for one have a Virtual Record mode that it was not possible to play in any other device.
And Orion do make products for Goodmans.
Most likely the first answer though.
Posted on Feb 17, 2008
Burning home movies from recorder to disc
make sure its finalizing the disc you may have to go into menu or options to check, but if plays in the but not in standalone thats sounds like the problem.
Feb 13, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Playing recorded DVDs on PC or other DVD player
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Aug 23, 2008 | Philips DVDR3455H/37B
Playing burnt DVD disks on other dvd players
It is very possible that the head alignment on your DVD recorder is a little out.
Also, make sure that you are closing the session after doing the recording (burn). If the session is not closed, the DVD will not be playable on other players.
Jerry G.
Aug 10, 2008 | LG RH1777 DVD Recorder
Hi I bought a goodmans dual format dvd recorder GDVDR319, tuned in fine, plays fine etc but the picture is pink. Instructions say check the video output but no idea what that means. Thanks
If your normal TV pictures are ok then carefully check your scart plugs are pushed right home and fitting squarely at the TV end and the DVD end.
Jun 14, 2008 | Televison & Video
There should be no problem with copying home recorded VHS tapes to DVD via the Scart or Video (yellow) output. It may be obvious but have you tried recording directly from other sources such as TV etc. Apologies if this is a trivial suggestion!
Apr 04, 2008 | TruTech T650-DR DVD Recorder
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Tranfer mini cd to a normal cd?
put the CD back in the casmcorder, and hook up the camcorder to your tv. put a blank disc in your dvd player and play the small disc through the camcorder on the tv. while the camcorder is playing the recorded stuff, press record on the dvd player and it should burn the stuff onto the blank cd.
Jan 10, 2008 | Panasonic VDR-D200 DVD Camcorder
Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Jan 02, 2008 | RCA DRC8335
Buzzing noise
could it be your monitor or tv??
try playing on another machine
i have and old vhs/tv combo that is use for my job
and i use to record on it around the clock as a security cam - so it has a lot of hours on it
when i record it like security cam -- the sound is going thru it just fine -- but when play back i have the buzz/roar
i was told by an engineer the heads are gon
Sep 27, 2007 | Sony RDR-VX555
Samsung dvd recorder model vr-325
Ok I have been here before. The problem is your DVD burner in your DVD player unit may not be burning the disk in a format recognized by the Computer, or the laser may not have burned the disk to the set standard, and while it can play on that DVD player when you move it to a nother player it will not play. Well what we can do is Test the reverse first. Burn a DVD on your computer and try to play it on your DVD player and on the other TV. Then what I want you to do is to clean the lens of the player and try to burn a disk and play it on your computer. Let me know how this truns out.
Sep 10, 2007 | Samsung VR-325 DVD Recorder / VCR Combo
Sony DVP-NS530 DVD Player Logo
115 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
