Question about Philips DVP-3005 DVD Player
Dvd player sticks
My dvd player playes for 15 min perfect then it startys pausing then jumps to next chapter
  • newfegirl Feb 18, 2008
    Yes, it does it to all disc.new and old one.If I let it run to-20-minuits it comes back and plays for 10-15 more minuits then pauses and starts again at another chapter
  • Anonymous Feb 20, 2008
    The dvp 3005 plays videos properly but hangs when I try to time seek to any point beyond 22mins.
  • 70 Answers
Sounds like a bad disc, does it do it on all discs and all at 15 mins?
Posted on Feb 17, 2008
Tip
This player is a big,huge hunk of ****.problems since i got it in 2001:...
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-35 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor depending on the area you live in. The best thing is to do some comparison shopping and call the different repair shops and get estimates. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
2. The tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull/push to hard on the tray (which you should not really do anyway, but always use the open and close button). This is an example picture of the drive assembly with the tray open.
3. The small gears are plastic and often break, this will cause the players other parts to not move and function properly. They are difficult to reach, but inexpensive to replace. It is always recommended that you always order any part from the manufacturer of the device. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are difficult to put back on as well, so you may need an extra pair of hands if you have not done this before. On average you will usually have 2-3 of them inside your player.
5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might consider purchasing another player depending on how much you want to spend and the original cost of the device, unless you can find a great deal on the part you need. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc. You can also see the spindle/spindle motor.
Picture of the optical reading assembly dismantled:
6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on (located in the drive assembly). Check these two components if you are having problems with your tray not opening and closing properly or stops working completely. Sometimes, the tray will open and then immediately close on it's own. This is usually caused by the track being dirty or some type of debris is lodged in the track. Cleaning the inside of the player with a can of compressed air will help remove dust and dirt. Blowing out the inside of the device once a month is a good preventative maintenance measure.
CAUTION: When working with any electrical device, you should always ensure safety first. Make sure that the device is turned off and unplugged from any power source. This does not completely prevent electrical shocks because Capacitors will hold an electrical charge for some time even if the device is turned off and unplugged.
The following are example pictures of what Capacitors look like:
on Jan 06, 2010 | Philips DVP5140 DVD Player
Dvd player pauses while playing a dvd
Yup they can do that when changing chapters. It is more noticeable on some players then others. If it did not do it when new maybe cleaning the lens may help.Otherwise it is likely a integral I shall say deficiency for that model.
Jan 12, 2013 | Sony NSZ-GT1 GOOGLE Internet TV Wi-Fi...
How do I play a movie on my Samsung blue ray without a remote
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc.
2.DISPLAY :Displays the playing status, time, etc.
3.Remote Control Sensor :Detects signals from the remote control.
4.OPEN/CLOSE BUTTON :Opens and closes the disc tray.
5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track.
6.STOP BUTTON :Stops disc playback.
7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback.
8.POWER BUTTON :Turns the Blu-ray Disc Player on and off.
9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected
to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
Jul 26, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Small glitches with home-burnt DVDs only
Gents,
Not a solution but in case it may help other's understanding with a similar problem, found glitch to be related to the default Chapter-making process within the Panasonic DVD recorder when dubbing a DVD. Default appears to be 5 mins 20 seconds per chapter, i.e. 320 seconds. Glitches from these DVDs are seen regularly on two of my four DVD players at every 32 seconds, i.e. one-tenth of the chapter length. Can't explain why this happens, or why indeed two of the players sail-through this recurring glitch without problem.
Colin Doman
Oct 04, 2008 | Philips DVP-3005 DVD Player
Playback of audio files does not resume where I left off when powering back on
I have an e260. I use it for audiobooks a lot. I just press pause (centre top of the dial), and the track will resume from there next time (unless I go back to the main menu for radio of course.)
Aug 16, 2008 | SanDisk Sansa e250 MP3 Player
Code for dvd player dvd252
Pioneer DVD player (DV-505, DV-525, DV-606, etc.) Note: Some codes work on LD/DVD combo players only, such as "Disc side A/B".
Note: The LD/DVD 0525 code will work too, but the arrow keys (among other things) won't work without being keymoved to the correct codes.
000 Chapter prev
002 Pause
003 Scan reverse
012 Disc side A/B
014 Random
028 Power on/off
029 Step/slow reverse
030 Audio
031 Exit?
033 Menu
034 +10
035 Power off
061 Power on
062 Power on
063 Demo (when player is off)
064 Power on
067 Reset (when player is off)
076 Program
077 Repeat A-B
078 Disc side B
080 Disc side A
082 Enter
084/086/088/090 Shuttle reverse
085/087/089/091 Shuttle forward
092 A/D/CX
093 8
097 9
140 Return
142 Last memory
143 Up arrow
147 Down arrow
150 Subtitle
156 Title
157 Mode (set-up)
158 Open/close
160 Angle
161 Condition
162 Step/slow forward
163 Chapter/time/frame search
191 Chapter next?
195 Chapter prev?
196 Right arrow
203 Left arrow
204 Repeat
205 Time search
208 Clear
209 Chapter search
211 Display
212/214/216/218 Jog reverse (w/still)
213/215/217/219 Jog forward (w/still)
220 4
221 0
222 6
223 2
224 5
225 1
226 7
227 3
252 Chapter next
253 Stop
254 Play (will turn on player and resume if player powered off)
255 Scan forward
Jul 11, 2008 | Televison & Video
DVD Player reads Unreliably
your dvd needs to be serviced have a tech look at it, if that does not fix your problem replace your dvd for another one. good luck
Jan 06, 2008 | Televison & Video
Skips to new chapters
I"m also having this problem. Very Annoying
Jan 01, 2008 | Memorex MVD2042 DVD Player
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Philips DVP-3005 DVD Player Logo
211 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
