Printing and copying probelm
I am having problem with this to take print and copy. Scanner is working fine. Catridge is over 3/4. Can you help me please?
  • 123 Answers
Is there a problem across your network or is it just your pc, check your memory, virtual memory and hard drive space... good luck...
Posted on Feb 19, 2008
Laserjet cm1017
Will it make a copy?
Do you get an error message?
Mar 18, 2014 | HP Office Equipment & Supplies
Copies do not print properly
Have you tried to reset the printer to factory defaults? possibly a internal software problem if everything else works fine, have you tried to scan a document to your pc?
there may be a firmware update available.
Jul 21, 2008 | Brother MFC 9700 All-In-One Laser Printer
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
HP Officejet 6210 will not copy, scan or fax. It will print documents from the computer. Any attempt to do the other 3 functions results in it being "busy" and cannot cancel, have to power it off.
Well if it is printing,the drivers are working fine.The copying,faxing and scanning mechanism use the same scanner to copy the image.It seems to be a problem with the scanner mechanism on the printer.Try a reset using the # and 6 buttons while plugging in the power cord.If it works well and good.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
CARRIAGE JAM
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 01, 2009 | HP Officejet 4355 All-In-One InkJet...
HP CM1015 copy/scan problem
DO THIS CHECK WHERE THE CATRIDGES IS IN ORDER.OR IF IT IS LEAKING
Jan 17, 2008 | HP LaserJet CM1015 All-In-One Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
73 people viewed this question
k24674
jasbo
jasbo
