Question about GE JVM1650SH Microwave Oven
Microwave shuts off after 2-5seconds
When i turn it on it runs for 2-5 seconds and then shuts off and goes to the clock setting mode.
  • Anonymous Feb 07, 2009
    ivm1650shoi
  • Anonymous Mar 14, 2014
    MICROWAVE ONLY RUNS FOR 5 SECONDS, THEN SHUTS OFF
  • GE Master
  • 9,098 Answers
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Microwave doesn't start but the interior light goes on when you hit the start button
Hello
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
The light inside goes on but the microwave doesn't
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The problem is most likely the magtube, it takes aprox 3 sec for the tube to energize and then it kills the microwave. If you drop the control panel away and start the microwave 90% of the time it will cook fine.
Nov 19, 2006 | Emerson MW8102SS 1100 Watts Microwave Oven
GE JVM1650SH Microwave Oven Logo
174 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
