Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Dishwasher will not fill with water - Frigidaire 24 in. FDB126RB Built-in Dishwasher
  • 7 more comments
  • scottnashley Feb 17, 2008
    i have a blanco dishwasher that will not stop draining - you can hear it churning away- and will not start the wash cycle. we have pulled the filters out and cleaned them, we have removed the pipes under the sink to clear the drainage hole for blockages and it still won't run. it is brand new and came in the brand new house we built and we have owned it for all of three months. help!
  • andre mckee Mar 05, 2008
    water will not come into the machine
  • Lanette1 Mar 08, 2008
    We had new counters put in (and air gap removed) and now our Jenn Air dishwasher will not fill with water.
  • Anonymous Jun 30, 2008
  • jstroz Jul 06, 2008
    I have a Bendix DWN 41 BX dishwasher will drain water but won't fill or go to the next cycle have checked all connections. Manually fill it will drain ok but just whirrs and nothing else. Having take off the side to check if the solenoids are ok "water inlet side" could this be a problem with these machines.
  • krugby Aug 24, 2008
    i have a ge adora dishwasher that will not fill with water??
  • glowilson Oct 28, 2008
    i have a kenmore ultra the motor is running but there is no water
  • glendahaz Dec 01, 2008
    I have a Frigidaire FDB956RBC0 Dishwasher and it will not fill with water. I have checked the water supply and the hose into the washer and they are good. I have also checked and cleaned the float. I can hear the clicking sound under the float, but still no water. I heard something about Frigidaire losing their water prime. Could this be the problem. If not, any help would be great. Thank you
  • andre mckee May 11, 2010
    I can hear the clicking of the switch and all leads are good , stillno water
    Habit-Forming:
  • 35 Answers
For no water coming in it can be the water supply is not turned on, follow the coper tube to the supply line and make sure any valves are turned on. Then check the electrical valve wires on the side of the washer or behind the bottom plate. the electrical valve may be bad this is vary common. The water level float could be sticking making the machine think it is full this is usually a mushroom shaped plastic part in the basin that can be pulled up and down push it down and see if the water runs. the timer circuitry cold be bad as a last posability.
Posted on Jul 30, 2008
    President:
  • 1,314 Answers
There are three or 4 possibility's here remove the kick plate make sure the water valve is plugged up make sure the water is turned on make sure the safety float hasn't slipped off the micro switch that's the dome shaped object in the tub the micro switch is underneath next when you first turn it on do you hear the pump motor run check theese and let me know
Posted on Feb 17, 2008
I have a fregidaire dishwasher, It will not fill up with water, It will empty out but wont fill up.
Please help,
Al
Posted on Mar 02, 2008
My dishwasher won't fill with water. and keeps running even when the door is open.
A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Dishwasher Repair Guide - Dishwasher won't fill with water..
or try this link..
dishwasher won fill with water Google Search
Oct 27, 2017 | Dishwashers
Boscsh shu3322uc dishwasher won't fill. If I put
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 09, 2011 | Bosch SHU3306UC Built-in Dishwasher
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
My neff dishwasher is not filling with water
Hello
Water inlet valve is responsible for filling water in your dishwasher, when that goes bad either the dishwasher wont fill at all or will fill the water slowly. Please check the inlet screens and also try to clean the water lines for any clogs/obstructions. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Neff Dishwashers
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
Dishwasher wont fill with water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Sep 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
953 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
