Question about Sanyo DP26746 26 in. LCD Television
How to record from my Sanyo DTV to my Sony Recorder?
Body: I want the Easy Setup Menu from my Sony DVD/VIDEO recorder to show up on the screen of my Sanyo DTV. The instructions from Sony say, "Switch the input selector on your TV so that the recorder appears on the TV screen." There is nothing on the Sanyo remote that says, "Input Selector." What do I do?
  • Anonymous Mar 26, 2014
    On initial "switch-on" ,screen advises to "configure recording list " ??? How is this accomplished please ?
    Scholar:
  • 84 Answers
First have the video recorder connected to the tv correctly,either coax out, red.white,yellow out, componant out or hdmi.[ see on back of the unit & the tv which connection you used.input selector is also known as video/source/line in or aux, sometimes even game. if there no such button on your remote, scroll down from channel 2 and you should be in some aux input.have the dvd playing,then you should see the video when you get to the right input.
wg
Posted on Feb 18, 2008
Hello, I need to reset SONY RDR-VX515. Thanks
Hello
To reset your RDR do the following
Press the System Menu while the recorder is in stop mode.
Select "Setup" and press enter.
Select "Easy Setup" and press enter.
Select "Start" and pre Enter.
Follow the instructions. OK.
Feb 21, 2011 | Sony RDR-VX515 DVD Recorder/VCR
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
RDR-GX315 was accidentally reverted to "Factory Settings" ... now we can get sound but no picture and progressive is turned on and we need to turn it off.
If your TV has progressive scan capability, you may be able to view the on-screen setup menu via the recorder - select 'SETUP' press 'ENTER' on your DVD recorder's remote to bring up the menu - with the remote arrow buttons, scroll down to select 'VIDEO' then 'PROGRESSIVE' - highlight it then set it to OFF (you cannot do this with a TV that does not support progressive scan from this unit). Once done, exit the setup menu and it should work fine with all the other settings. If your TV doesn't have progressive scan, connect the DVD recorder to one which does and turn its progressive output off there. I assume you still have the user manual for your recorder (if not, you can download it online for free as an Adobe document - .pdf. Page 73 details the setup steps for this model). I hope this tip helps somewhat.
Feb 11, 2011 | Sony RDR-GX315 DVD Recorder
Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
May 08, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
How record tv chanels using the DTV converter box? The converter box determines the chanel of interes while the DVD recorder must remain on chanel 3 in my area. My DVD recorder is a combo with a VCR...
Can you connect directly from the DTV converter to the DVD recorder input using RCA phono connector cables? You'll have to select the input on the recorder menu as well.
Oct 21, 2009 | GoVideo Go Video DVD/VCR Combo
Small picture from player (not wide screen)
Set the all settings to wide, not auto as if the player is set to 4:3 format then this sends a signal to the tv telling it so.Go into the setup menu and choose picture format set to 16:9 or wide. Set the tv to auto and this will keep all picture inputs to origional format. I.E. if it was recorded in 16:9 it will play in 16:9. You could set the tv to 16:9 but it will distort the picture on 4:3 recordings.
May 31, 2009 | Sanyo DRW-1000 DVD Recorder/VCR
Cannot access the "guide" facility "t
i had a similar problem with the 870 model. i reloaded all the channels using the "initial setup" menu and everything was back to normal. charles
Apr 25, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Command mode change
Pretty easy, Recorder shows DVD1 in display..OK Slide COMMAND MODE Switch to DVD1 on remote Control. This switch is located in lowe part of remote control and has 3 settings.
Jan 04, 2009 | Sony RDR-VX521 DVD Recorder/VCR
Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
Apr 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Jun 03, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo DP26746 26 in. LCD Television Logo
121 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
