Question about Car Audio & Video
2000 watt legacy predator amp
My protect light will not allow my subs to work why want it go off.
  • Tryston May 05, 2008
    I unhooked all the wires but power remote and ground to my Soundstorm F2800 and it still has the protection light on what do i do????????
  • bigfoot0r May 05, 2009
    i have a 2000 watt legacy preditor amp and no matter what i do it goes into protect mode ive tries everything
I want to disconnect amplifier and remove from car. The cable is still connected to the battery, is this likely to cause problems?
Lea
Posted on Sep 28, 2008
  • 631 Answers
Disconnect all speaker wires from the amplifier's speaker terminals and disconnect the RCA cables from the amp. If the amp still goes into protect, it probably has shorted output transistors.
Posted on Feb 17, 2008
I have a Legacy Predator 2000 watt amp with 2 12'' Kicker speakers. It has been in my car for about a year now, and it recently just stopped working. I have the green light to the amp, im not sure about...
If you have checked your ground, live, remote and RCA's, The problem may lie with your kicker speakers.
There may be a loose wire connection on the speaker terminals (hense no sound).
Check the terminals at the speaker (+) and (-) then check the speaker wires to your amp inputs.
Usually if there is a fault with any wires linked to your amp, the amp goes into protect mode.
If your amp is not going into protect mode, try linking a different speaker to each terminal on your amp (left) then (right). If you get sound through a different speaker, more than likey your speaker wire to your kickers has came loose (due to vibrations) or there is a break in your speaker wire.
Hope this helps. If any more info is needed I'd be happy to help more. Please rate if helpful
Mar 18, 2011 | Car Audio & Video
Legacy LA770 worked for 2 10" subs but not for 1 12" sub
if the protect light is still on with all speakers disconected then you have overloaded the internal ic and blown it beyound its ability to reset
sorry
Jun 25, 2010 | Legacy Audio LA770 Car Audio Amplifier
Legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
Mar 01, 2010 | Legacy Audio American Legacy II LA590 Car...
I have 2 kicker cvr12s and a legacy predator 2400 watt amp and when I turn the radio up the amp goes into protection once they hit a decent time. I just down graded from 15s so I know its not a power...
you prolly have the subs wired to a too low of an ohm load...thats what happend to me. i had the same subs, and a 500.1 watt amp...and they still blew up..whire EACH sub to a 4 ohm...that should work.
Nov 18, 2009 | Car Audio & Video
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
LA-1030 Protect Mode
you have an unloaded channel,so the voltage is exceeding what the protect circuit is supposed to see.you have to connect an 8 ohm resistor across the output of the unused channel.
do not drive a signal into it or you will smoke the resistor.
a 10 watt will do ok with zero signal input
May 23, 2009 | Legacy Audio LA1030 Car Audio Amplifier
Kole amp in protect mode?
Are you setting the bridge switch for both left and right or are you trying to run both subs off of one set of terminals? If you running the subs off one set of terminals you are effectively running the amp below 2ohms and thus the amp is not 2ohm stable and you will destroy it.
Some amps actually all ready run a bridged output for left/right operation, this could also be the reason why the protection circuit is kicking on.
Either way it's a component mismatch and you either need a stronger amp or different subwoofer setup.
Mar 09, 2009 | Kole audio Nitric XP2-2000 Car Amp
Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Car Audio & Video Logo
376 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
