Question about Panasonic Workio DP-2330 Printer
Networking a Panasonic DP-2330 Multifunction printer/copier.
First of all I don't have an installation CD-ROM. A small office has been using this device as a copier only. Unit was vastly under utilized and they needed more printing capacity for their small inhouse lan. So, I'm trying to add this unit (DP-2330) to their existing network. Network setup... DLINK 2310 router with a NETWORK EVERYWHERE NH1005-wm 5-port hub (for added ports) and a standard DSL modem to provide hi-speed net access to the connected PCs. I have tried downloading the printer drivers from panasonic.com and installing them, several times. At first I tried using a DLINK 1260 print server, but I don't think that the server is compatible with the Panasonic's USB connection. I have a direct CAT5 cable between the DP-2330's ethernet port and a port on the working networking equipment. Whenever I try to do an "Automatic Config Update" from the printer software control panel, I get an error saying that the PC can't communicate with the printer. The printer has never printed a "test page". I believe that the mac address of the printer needs to be installed in the router configuration (as all the other pc's are). Using DCHP on the router. Can't figure out how to find printer mac address... no documentation is available; or is that even a concern at this point? I hope you can follow this and give me some helpful advice. It would be most appreciated. Thanks.
  • 2 more comments
  • pittfall2006 Feb 17, 2008
    CAT5 cable works fine anywhere else on the network. Cable was also independently tested OK before adding it to the network. I have not been able to adminster the 10/100Tbase RX.
  • pittfall2006 Mar 23, 2008
    Thanks for your tip. I found the MAC.
  • aman1 Jun 03, 2008
    Copier is not working. It gives an error message "Check printer Print E04-01"
    Also asking for a code if I try to pring...I don't knoe the code!
  • Anonymous Jan 19, 2009
    print
Hello the MAC address is #28 located on the General Setting list under Function menu. Print it off. The key opp code is ussally 0000. Good luck I am in the same boat.
Posted on Mar 12, 2008
I have a panasonic printer but drivers is also remove with windows and my printer cd i forget so this time my computer in so software in panasonic dp-2330 printer i want reinstalling printer in computer so u till suggesting
Posted on Aug 13, 2008
Need Panasonic WORKiO® DP-2330 driver
Hello , this is the link for the most up to date driver. Just choose your language and operating system
Thank you.
http://www.panasonic.net/pcc/support/mfp/dp-3030/gdi/download.html#01-2
Feb 09, 2010 | Panasonic Workio DP-2330 Printer
How to scan
My dp 2330 copier prints dark shades(0.5 thick dark lines) even though the text you want to print is seen in the back ground. pls what should i do or whats the problem? Thank you .
Sep 11, 2009 | Panasonic Workio DP-2330 Printer
How to print envelope on Panasonic DP-2330 printer
You can download a user's manual from here.
It's a pretty large file, so I'm guessing there's something there about paper feeding or envelopes that will help you.
Good luck.
Aug 31, 2009 | Panasonic Workio DP-2330 Printer
Panasonic 2330 servicecode
Try 0000. That´s the original operator code of my Panasonic DP-2330 office machine.
Feb 06, 2009 | Panasonic Workio DP-2330 Printer
Need drivers for panasonic dp 2330 printer
You can download your driver here: http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=88287&catGroupId=13843&surfModel=DP-2330&displayTab=R
Just click on the driver download & select the driver for vista. Hope this helps & please remember to rate my answer. Thanks.
Jan 09, 2009 | Panasonic Workio DP-2330 Printer
Machine reboots
maybe it thinks it has a fax option..delete the panasonic then re-install. make sure you reboot the computer. Some software requires you to restart the computer.
Jun 27, 2008 | Panasonic Workio DP-2330 Printer
Panasonic DP-CL21 drivers- HELP
for you to use this machine on a MAC you need a PCL board installed in your machine.
Jun 14, 2008 | Panasonic Workio DP-2330 Printer
Panasonic Workio DP-2330 Printer Logo
1,692 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
