Question about Hotpoint Aquarius WMA52 Front Load Washer
Door will not lock
Hotpoint Aquarius WMA52 has got an intermittent fault. Program starts and then at random "door unlocked" light illuminates and program stops. Is this something simple like a reset needed?. If so, then how?. Or does it need a part and a service call?.
Any advice gratefully recieved
  • 417 Answers
Sorry I think it needs a service call as the door control is controlled by the main board if not the part is the door lock.
Thanks J
Posted on Feb 17, 2008
Hotpoint wd62 washer dryer does not start indicater light doesnot light up. have checked line fuse and socket thanks
It is probably a faulty door lock, a common problem.
Remove front of door seal by releasing the wire clamp, and unscrew door lock, it has 3 wires going to it, to prove it is the door lock, short out the 2 wires marked C and L ,it should now work, if it does not , then the fault is elsewhere,, but I feel confident this is the problem.
Please rate my solution.
Feb 28, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Door lock flashes doesnt work or start up
The flashing door lock light is indicating that the door is not closed proerly.
This can be caused by a weak or broken spring in the door handle.
Another reason for this to happen, is a faulty control board at the top of the washer, a blown track will cause this.
This in turn, is usally caused by a fault on the motor.
Hope this helps.
Jan 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
The final spin light is flashing and its not spinning the clothes
is the door locked light lit did all the water drain out(plugged pump) will it turn in the wash cycle (no, belt broke or came off)
Dec 08, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
The door lock light keeps flashing and wont wash how do i solve this problem?
check door is closing correct if not the machine will never start if this is ok check main pcb
Jun 08, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint WD63 Random Fault
if the drum will not turn it may be the motor brushes
Sep 30, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Nov 03, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
NO POWER
easiest way to get the clothes out is to power the pump up independantly of the machine. you will need a length of mains cable and connectors. having got the water out, you should be able to remove clothes. another way is to put the drain hose down at floor level into a bucket and this will drain most of the water away. the actual fault is rather more difficult but check there is power the machine side of the mains suppressor. another possibility is the door interlock.
May 11, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
178 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
