Conecting a rf modulator to cable box
When i follow the directions to connect the rf modulator it by passes the cable box which controls the channels how do i set this thing up?
  • 70 Answers
Your cable box should also have an RF in and out so you can connect it to that also. What are you using the modulator for?
are you using it to connect a digital security camera?
Posted on Feb 17, 2008
How do I reset error code SC548
25685181-yl5nsd0dwyytd1n2wv4v20hl-5-0.jpg OR
Sponsored Link Shop Bulk Wire & Cable
Network, Telephone, Coax & A/V. Quantity Discounts & Same Day Ship!
showmecables.com/Bulk-Cable STEP 1 Purchase the RF modulator at an electronics store. The modulator is used to connect your older television to cable.
STEP 2 Plug the RF modulator in a power outlet near your television. It is best to plug it near the television to allow for easy access.
STEP 3 Connect your television to the RF modulator by inserting the one-prong cord that is on back of your television. Insert the cord in the slot on the modulator that reads, "To TV." On older televisions, this cord is the only cord in the back.
STEP 4 Connect one end of the white one-prong cable to the cable box and the other end in the RF modulator. Connect it into the modulator in the slot the reads, "ANT IN." Usually, the cables are provided by the cable company--the technician uses them upon installation. This particular cable may run along the side of the wall to your cable box.
STEP 5 Turn on the cable box and the television set. Everything should be working properly. On the RF modulator, choose the channel for the television (either channel 3 or 4). The modulator turns on when you plug it in.
May 08, 2015 | Office Equipment & Supplies
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    I cant get my dvd to play using my rf modulator
    instead of plugging in the rf modulator before the cable box, i plugged it in after it
    Jan 24, 2009 | GE 25GT240 25" TV
    RF module related to Direct TV.
    yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
    Oct 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
    Need directions to install a dch70 box to tv
    dear woolifer ,
    I am not an expert but i hope i can help you..
    is it youmean digital cablebox?
    if it is try this-
    This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
    As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
    1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
    2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
    3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
    4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
    5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
    This should be all you need to get started watching your digital television. In simple terms here is what you did:
    Coaxial from wall to cable box
    Cable box to VCR
    VCR to RF modulator
    DVD player to RF Modulator
    RF modulator to TV
    You will only be able to record what is on channel
    Apr 09, 2008 | Computers & Internet
    Conecting DVD/VCP to tv through DIRECT SAT. BOX
    You will need what is called an RF modulator. What this device does is to take the place of the internal mod that Used to be included on old VCR/DVDs....accordianman
    Feb 26, 2008 | Televison & Video
    Daewood input w/out remote
    Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
    Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
    Zenith xbr716
    ALL cable is digital.
    What type of TV do you have? Does it have any scart conections on it? If not connect the Cable box with a scart lead to your VCR select the AV channel on your VCR, connect your VCR to your TV via the RF connection, (if it has not got one, its not a TV, its a monitor). Tune your TV in to the video channel.
    You do not need an RF modulator for a home TV setup, whoever told you that is a fool.
    Dec 28, 2007 | Zenith XBR716
    Televison & Video Logo
    184 people viewed this question
    Top Televison & Video Experts
