Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Suction Problem I took my unit to my work and used it, when I returned home it wouldn't suck up anything. I took the recovery take out and it has inward suction. Shouldn't that be outward, so it goes into the tank? It also blows out of the bottom by the brushes. I check the filter in the bottom and that is fine. Is it possible that it is somehow reversed the direction of the air flow (rotor running backwards)? I am perplexed. What am I missing?
    President:
  • 1,673 Answers
There is a stand pipe seal where the bucket sits on, and if it isn't there or out of place could cause a suction problem like you said yours is doing. In the picture it is #10. The motor seal may have gone bad and is leaking # 15.
Posted on Feb 17, 2008
It will not pick up the water. Help !!!!!
Problem #1 - My Steamvac is not Sucking!
If your Hoover Steamvac was working properly and suddenly it is not sucking any water, nine times out of ten, the culprit is the lid on the lower recovery tank. The lid on the lower tank (or dirty water tank) needs to hinge at the front and snap down at the back in order to creat a proper seal. If the lid snaps on but is not locked on at the front, you will not get any suction. Simply take the lid off, and ensure that when you put it back on, it must hinge on the front tabs of the tank.
Problem #2 - My Steamvac is still not Sucking!
Right now you are thinking that you shouldn't have let your brother borrow your Steamvac. And you are right, because he used the hose attachment and returned it with the hose still attached to the front of the tank (some models only). Now when you try to use it there isn't any suction. In this case, you are missing your tank duct. On models where the stair/upholstery hose attaches to the front of the recovery tank, one must remove a square plastic piece in order to attach the hose. This square plastic tank duct must be replaced before the Steamvac will operate properly in the upright position. hope this helps ive copied it
Oct 09, 2016 | Vacuums
The unit is not sucking anything up. checked for possible clogs in the hose - all clear. Took base off and cleared the bottom hose - put all back together and still not cleaning anything up.
There may be a screen filter beneath the bag that's clogged. Remove the bag, check, and clean if necessary.
Also, check the power head above/behind the brush. Things sometimes get caught in the tube between the brush and the hose.
There may also be holes or cracks in the hose will also reduce the "suction".
If these aren't the problem, take the vacuum to a repair shop, preferrably an authorized Riccar store.
Feb 23, 2011 | Riccar 4812 Vacuum
My 5200 hoover spin scrub all of a sudden stopped sucking in mid clean.i took the front clear cowling off and checked for blockage but couldnt see anything.there is nothing to these thiings,they are...
Most likely your vent for the suction container is plugged or the suction hose can of or is broken at the connection to the tank nozzle (very common on these. Clean the machine thoroughly, and check that all hoses are tight and connected.
Aug 01, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Floormate stopped vacuming water
I'll answer last question first. Your floormate has a 1 year warranty. And should be taken in for repair.
Your issue of not picking up water, is related to suction and getting the dirty water to the recovery tank. check for obstruction in the nozzle, check the filter for debris clogging. If you have an issue with this dealer I would call customer support.
Sep 26, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Lost suction, gasket problem
This is a great basic steam cleaner. I have not heard of repeated problems of this type. The gasket is called a standpipe gasket. I would try to use a non-permanent sealant such as RTV silicone to adhear the gasket, eventually if this needed service you will want the gasket to be able to be removed.
Feb 02, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
No suction
I used a new Hoover Spin ScrubSteam Vac the first time and it worked great. The next day it would not such up the water and sounded like it was sucking air. I took off the lid on the recovery tank and when carefully inspecting the gaskets saw a every so small slilt in the small gasket that surrounds the intake duct. I put some silicone glue on it to close and seal it. This morning I tried sucking up water on a tile floor and it worked OK! I have not tried it again on carpets but am keeping my fingers crossed.
Jan 06, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have a dyson that is picking up just fine when on vacuum mode, however when I try to use the suction tube there is no suction at all. It is not blocked and the canister is empty. Help!
Hi, I have an upright DC03, brilliant machine. Mine wouldn't **** and had the following symptoms;
- it sucked ok from the top hole where the canister joins the unit - with the canister the dust didn't spin aroun inside the canister like it normally does and there was no **** at the hose end or brush end. - with the top of the canister attached (the cyclone) but not the bottom it sucked through the cyclone - the small valve on top of the cyclone unit was sucking heaps
this indicated to me the machine was sucking through the cyclone unit but when the canister was put on it was blocked - hence the tremendous sucking through the valve on the top of the cyclone. As far as I could see the cyclone wasn't blocked so I poked some wire down the tube inside the machine that runs from the bottom of the unit (where the hose sits) up to the bottom hole where the canister joins.
The DC03 has 2 holes where the canister attaches, it seems like it sucks air through the top hole, through the cyclone and through the lower hole sucks the dust up this inner tube into the canister. Check that tube, shine a torch from the top hole and you should be able to see the light at the bottom. Make sure you clear it completely.
Mine was very very blocked. I kept poking and removing dust until I could see light at through the tube. Works fine now.
Hopefully this helps someone as it took me awhile to work it out.
Good luck
Aug 12, 2008 | Vacuums
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Water will not suck back up
try vacuming the water up w/out adding water our anything else to the machine
Mar 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Dyson not owrking in upright position
I've had this problem. On the lower left side of the vacuum you need to make sure that is completely attached. Pull the part with the arrow button up and push the compartment down. This will allow suction to continue
Jul 04, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
60 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
